We are currently using KiCAD to layout an 8 layer PCB layout with a BGA footprint.
One question came up regarding the annular rings for vias in inner layers:
If we do not have a track connected to a via, the annular ring should be set to a minimum value. This would help us to reduce the internal resistance of a surrounding copper area.
Some other PCB tools offer different settings for the annular ring width used for the outer and inner layers (e.g. Inner Annular Ring and Outer Annular Ring).
We have found nothing similar in KiCAD: There is only a single setting for the annular ring width for vias, used for inner and outer layer. Do we have overlooked something? Maybe there is someone who knows another trick?
We have used the latest release 4.0.0 RC1.
Please have a look at the green copper area VDDSOC_CAP in the picture below. The idea is to reduce the annular ring of the surrounded vias, not connected to a track.
Hi @Gerrit ,
if you want annular ring for inner layers smaller than outer layers you can trick the board adding something similar to the topic at nicer via stitching
you make a via module as following:
Case#1
then you import it in module editor and add to the board assigning the net.
if you need the opposite (inner vias bigger than outer vias) you can do a similar trick, but the DRC will give violation (so you should route disabling DRC)…
(the code is for e.g. 4 layers board)
Case#2
And know he want’s them annular rings to re-size depending on if a track connects to it on a layer or not.
For better understanding see this drawing of mine:
@Gerrit
Have you tried to play around with the Design Rules Editor settings already (in pcbnew)?
I think if you would design a via with the smaller annular rings as a base to work with as a footprint and then set up a net class/track class with a different via diameter it should be possible to get the behavior you desire?
I played around with this a bit and used a buried via with a custom footprint via that has got small annular rings on all 8 layers. The kicad_pcb file looks like this for the important bits:
I don’t know why it makes the annular rings on the layers in-between the start and end layer for the buried via big as well, but this might be able to be solved by some programmer more easily than any other workaround?
Maybe there is some option in the code somewhere to omit extra annular rings on other layers?
It seems to be working for the layers above and below the buried via, so why shouldn’t it for the ones in between?
[oops] - I deleted my previous post because I can see now exactly why those inner pads are large. The blind via spans layers 3-6, so all those layers will have the annular size of the blind via.
Anyway, we’ve known for a few years now that KiCad desperately needs a padstack and editor but so far no one’s had the resources to put into it.
as I posted a footprint module with different size pads is required…
(it is possible also avoiding blind vias)
I wouldn’t put *.Mask on this annular vias
and moreover you’ll get a DRC violation…
so it is a dirty trick
we will wait for a legacy padstack and editor…
You can now put tracks to this without DRC violations and when you make a buried via with bigger sized annular rings it will work..
So all that would be left to do for some programmer is to put in an option to tell the buried via method to not to create annular rings between the layers the buried via is supposed to connect.
Then you’d be done, as you’ll have at least 2 tracks going to the via at different levels, otherwise you don’t need any bigger sized annular rings anyway, right?
Or do I miss a case here?
Thank you very much for your hints! We will try it out.
I have talked now to the PCB manufacturer and got some news. They told me that we might simplify the things a bit, because they will remove annular rings from vias in inner layers anyway - if there is no track connected to it. They call them “Non Functional Pads”. Thy will do it with their CAM tools on gerber basis.
But even if thy do so, one problem remains: In our gerber files, the surrounding copper area will not be filled near enough to the via in inner layers (because the filling algorithm will see the annular ring there).
Maybe this problem can be solved without a padstack editor. In our case, it would be nice to have an option, removing all annular rings from inner layers, when they are not connected to a track.
I will keep you informed and post our results here.
Well, if it filled the zone all the way, there would be a pad again, a large one. Can’t have that if the hole is plated. Even for unplated holes it would be pushing one’s luck. Can’t guarantee that the inside surface of the hole is 100% free of copper, especially if the drill is a bit dull and starts smearing the stuff all over the place.
The case shown in the image above seems a bit excessive though. I guess it would be sufficient to keep the zone away from the hole by oh say 0.5x drill diameter, maybe less if the drill registration is optimal.
I’m happy about your support in this forum - thanks to you all!
Yesterday we’ve checked the proposal from maui, using pads instead of vias. This would solve our problem. We will see if we can define those pads within the BGA footprint, allowing us to reuse those settings for other projects.
Of course, all of this is a workaround, and a padstack editor would give us a much more elegant solution.
But in our case - we would also be happy with an option for the gerber export dialog like “Remove Non Functional Pads from Inner Layers”. This is something the PCB manufacturer will do anyway. It would be necessary that the released area of the annular ring will be used by the surrounding copper zone (respecting the clearance area around the drill hole). This option would also be useful if the padstack editor is completed one day.
For me it seems that an option like this is no witchcraft. I could ask one of our C++ experts if he is brave enough to try it.If this works we could contribute the code.
But what is you opinion? Would this option be useful for you, too? Would it be a an easy job to implement it? Or do you see any pifalls?
I think that would be a good idea…
please have a look at
a padstack editor would be a useful thing
you can ask at the developers mailing list if someone has already started something (but I don’t think so) and if there are some constrains to follow…
also the chat is available…
I like it. I don’t do 4 or more layer boards yet, but it would be definitely helpful if I ever came across BGAs where every little space one can get for routing underneath is worth it’s space in gold
Any more thoughts about this? I was referred to this topic, having had a related problem wanting special pads on the solder side only of through hole components, especially circular connectors and would find a padstack editor very useful for even two layer boards.
Its been almost a year so I hope there is solution for this, at least can anyone explain me where do you enter those code examples.
( and question aside, how come my 3D viewer doesnt show me layers like yours
