This should be the reason why I created & improved the WB ![]()
MD = MCAD Designer; ED = ECAD Designer; KC = KiCad; FC = FreeCAD; kSU = KiCAD StepUp
The workflow should be:
- MD would create a sketch of the pcb edge and mounting holes… (this could come also from a 3d model of the pcb converted to outline, as it is possible to get from enclosure manufacturers).
- From the pcb edge design (that could be a real FC sketch or an imported DXF converted to sketch using kSU WB tools) ED would push the sketch (edge converted) into an empty kicad_pcb file (or just a kicad_pcb file without any edge, with footprints and 3D models assigned).
- in kicad, ED would import all/some 3d footprint (i.e. the connectors) from a netlist and place them inside the kicad_pcb file in which the pcd edge has been previously pushed.
- in FC ED would pull the kicad_pcb with main connectors (using kSU) and export it to STEP, then export a report of placement to a file using kSU.
- MD would import the STEP hierarchy model generated from FC and kSU, aligning connectors to the real assembly needed for production, and the would export back the pcb + connector hierarchy model to STEP .
- ED would import the re-elaborated STEP model to FC and check what has changed its position through kSU (or just from a list of what MD had moved).
- ED would then select the 3D models moved and push those to the kicad_pcb to align KC design to the mechanical design.
- In case of changes in mechanical requirements the process would be repeated, aligning pcb edge/holes or 3D models to the new scenario.
The process can be done all using FC, or through proprietary mechanical CAD, using FC & STEP format as vehicle (the commercial package need to be able to keep the STEP hierarchy during importing/exporting the mechanical model, but most known packages will do).
This is a push-pull process that is the ‘standardized’ workflow for ECAD/MCAD co-design used by the main commercial packages, available now with all open source packages.
https://www.prostep.org/fileadmin/downloads/ProSTEP-iViP_Use-Case_ECAD-MCAD-Collaboration_1.0.pdf
