Post-V8 New Features and Development News
This topic will be used to announce new features and other significant development updates during the KiCad 9 development cycle.
This topic is only for announcements. Please start new topics to discuss new features.
Ethan Chien has contributed a new Zone Manager feature, which allows easy preview and adjustment of zone priorities and other settings:
Added text-justify actions (so that you can assign hotkeys to them, if desired).
Ability to override locked footprints when updating PCB from schematic.
Expand All / Collapse All for Footprint Editor and Symbol Editor.
@jp-charras added the ability to hide hidden fields from the symbol editor (View > Show Hidden Fields, and the spreadsheet icon on the left toolbar – this icon is a placeholder until we design a new one)
Ability to add comments to ERC and DRC exclusions.
Selection filter for schematic/symbol editors
Ethan Chen has contributed a new sheet pin/hierarchical label synchronization tool. This tool provides management of sheet pins and their associated hierarchical labels instead of having to switch back and forth between the sheet and schematic.
sync_sheet_pins
Added support for importing Altium Schematic in ASCII format.
Backported to 8.0.2.
Previously only binary Schematic/PCB/Library Altium formats were supported.
Added PCB 3D image raytracing rendering from CLI, with transparent background support.
Usage string
Usage: render [--help] [--output OUTPUT_FILE] [--define-var KEY=VALUE] [--width WIDTH] [--height HEIGHT] [--side SIDE] [--background BG] [--quality QUALITY] [--preset PRESET] [--floor] [--perspective] [--zoom ZOOM] [--pan VECTOR] [--pivot PIVOT] [--rotate ANGLES] INPUT_FILE
Renders the PCB in 3D view to PNG or JPEG image
Positional arguments:
  INPUT_FILE        Input file
Optional arguments:
  -h, --help        Shows help message and exits
  -o, --output      Output file [nargs=0..1] [default: ""]
  -D, --define-var  Overrides or adds project variables, can be used multiple times to declare multiple variables.
                    Use in the format of '--define-var key=value' or '-D key=value' [nargs=0..1] [default: {}]
  -w, --width       Image width [nargs=0..1] [default: 1600]
  -h, --height      Image height [nargs=0..1] [default: 900]
  --side            Render from side. Options: top, bottom, left, right, front, back [nargs=0..1] [default: "top"]
  --background      Image background. Options: transparent, opaque. Default: transparent for PNG, opaque for JPEG [nargs=0..1] [default: ""]
  --quality         Render quality. Options: basic, high, user [nargs=0..1] [default: "basic"]
  --preset          Color preset. Options: follow_pcb_editor, follow_plot_settings, legacy_preset_flag, ... [nargs=0..1] [default: "follow_plot_settings"]
  --floor           Enables floor, shadows and post-processing, even if disabled in quality preset
  --perspective     Use perspective projection instead of orthogonal
  --zoom            Camera zoom [nargs=0..1] [default: 1]
  --pan             Pan camera, format 'X,Y,Z' e.g.: '3,0,0' [nargs=0..1] [default: ""]
  --pivot           Set pivot point relative to the board center in centimeters, format 'X,Y,Z' e.g.: '-10,2,0' [nargs=0..1] [default: ""]
  --rotate          Rotate board, format 'X,Y,Z' e.g.: '-45,0,45' for isometric view [nargs=0..1] [default: ""]
Isometric video render example:
kicad-cli pcb render --floor --zoom 1.4 --rotate '-45,0,45' -o render.png video.kicad_pcb
Previously it was not possible to use kicad-cli for rendering 3D images.
JamesJ has moved the Net Inspector to a docked panel (View > Show Net Inspector to show/hide)
This includes improved filtering and grouping UX, the ability to show/hide and reorder the columns, and save/restore of all the settings.
Jan Wichmann added tolerance calculations to the calculator regulator panel.
Miklós Márton added an option to change sheet names in the schematic hierarchy navigator.
Solid 3D model export improvements:
  • Option to fuse copper geometry together
  • Option to export copper on inner layers
  • Options to exclude board body or components
  • Net filter (can be used to export a single net)
  • Zone geometry approximation with arcs for faster processing and smaller file sizes
  • Export in BREP or XAO formats
XAO defines pad surfaces as face groups and can be imported into SALOME or newer versions of Gmsh for FEM simulations:
Extended the physical_clearance rule to apply between copper fills & footprint courtyards.
(rule "No copper pours under Capacitors"
    (constraint physical_clearance (min 0.1mm))
    (condition "A.Type == 'Zone' && B.Reference == 'C*'")
will knock out the courtyard of any footprint whose reference starts with “C” from all copper fills.
@JamesJ added support for schematic rule areas that allow users to draw a shape to which net class directives can be attached.
small tool added (by S.Hillbrand) to the context menu: Shape modification–> simplify polygon
Control over via tenting on top and bottom sides, at a board level and per-via overrides.
Note: this replaces the “tent vias” checkbox in the Plot dialog, which is now gone.
