STEP Export from PCB
I am running RC2.
All my 3D models are of type STEP.
How do I export a .STEP model from PCB layout editor ?
You use StepUp which is a plugin for FreeCad… this produces smaller models than KiCad directly which seems to crash Solidworks at least for me.
Then freecad will be able to open kicad_pcb files.
There is a Guide for how to set it up here:
File->export->step
and some more characteres
Thanks.
File->export->step works for me.
Question, when using 3D viewer pcb tracks and pad are visible.
Using ā€œexportā€ tracks and pads are not part of the export. Is this a configuration issue or ??
( KicadStepUp, i’ve looked into that and I prefer not learning a new tool for getting a step file )
As you are exporting a mechanical CAD file, you are interested on the overall mechanical dimensions and form of the object. Adding tracks and pads to a STEP file would be overkill in complexity for the proposes.
Indeed, the guys over in the technical department where I work already have issues loading KiCad step files (slow)… so no use adding things they don’t really need that would slow it down even more and or make it more crashy on import.
Well… I am not in completely agreement with you guys.
Yes, we are using step for checking the mechanical dimensions but, we are also interested in generation good looking images of PCB and enclosure together.
So, this should maybe be configurable ???
I would suggest to convert the case/enclosure to WRL and then add it in kicad, Blender or what you would like
Maybe @maui can comment, but I thought I remember hearing about using a special technique with StepUP to export a board with traces to FreeCAD (where you can then save out as STEP.) I could be completely wrong as I can’t find anything helpful searching this forum…
Check out this board. It is also mentioned in another thread, try searching for the author of that post.
In general STEP is used for mechanical integration, so exporting kicad_pcb to STEP is the way to go for MCAD.
VRML is used for artistic content, then having all your models & enclosure as vrml will help you in getting a nice 3D rendering with all the tracks and pads as in real world (in v5 the 3D viewer is just gorgeous).
Moreover you can export the 3D vrlm view to be able to manipulate later in a more suited sw like i.e. Blender
I am not sure if this is the correct thread for this issue and I did not find any information that sombody else has this problem.
I am using the newest freecad stable 17.13528 on Ubuntu 16.04 and the StepUp Script V7.2.2.3 (latest I guess).
All models are imported correctly without any exceptions displayed. But then this is displayed:
exporting to MCAD
hierarchy
Exception while processing file: kicad-StepUp-tools.FCMacro [global name 'find_skt_in_Doc' is not defined]
File format not supported: master
The command was:
freecad kicad-StepUp-tools.FCMacro master
Thanks!
Hi @LukeLER
would you please update StepUp installing the StepUp WB through FreeCAD Tools Addons menu?
That will let use StepUp as a FreeCAD workbench and let you know if your release is up to date.
After installing StepUp as FC WB and close and relaunch FC, you will be able to directly open a kicad board in FreeCAD.
you may also find this useful
kicad-stepup-cheatsheet
Please let me know if this is solving your issue …
Maurice
I added the WB via the addon manager. But when I would like to open a board this appears:
that is a strange error…
anyway you could:
  1. close FreeCAD
  2. rename your old ā€˜ksu-config.ini’ (in your $HOME folder) to ā€˜ksu-config.old’ or just delete it
  3. relaunch FC and switch to StepUp WB and launch the StepUp tools
  4. adjust your 3D path in ā€˜ksu-config.ini’ accordingly to your need (or copy from your previous ā€˜ksu-config.old’)
    (it should be ā€˜/home/lukeler/tf/kicad-libraries/3d/’ )
Then it should work correctly.
Please let me know your progress :slight_smile:
Thats the reason why I am asking here … :smile:
I did the four steps you told me. The WB is working now correctly and I get a *.step and a *.FCStd file after importing.
But when I start the importing in the terminal directly the exporting to MCAD failed (see 2nd screenshot). (The same as i told in my first post here)
I tested it also at an fresh installed ubuntu -> same issue.
In the second screenshot is just ā€œhierachyā€ instaed of ā€œexporting hierarchyā€ in the first screenshot. Is this randomly? :slight_smile:
Second screenhsot here:
So you need to use StepUp through the terminal, launching it in the old way don’t you?
I will check if this method is still running or there are issues…
Moreover, could you please post your command log as text instead of a simple image?
Thx
M
Screenshot clipped, but referenced below
Thank you for providing that screenshot. I’ve been struggling with FreeCAD, but haven’t expended the effort to use the FreeCAD forums. I though that something was broken in my installation because of how the Addon manager window looks, i.e. no symbols in a left-most column of the list. Quite unlike the screenshots shown on FreeCAD’s website. Now that I see yours looks like mine, I fell much better that it is a bug with FreeCAD, not something that I didn’t install properly.
Now back to your regularly scheduled conversation.
Yes, thats true! It is easier for me an easier to document in our documentation.
Thanks a lot!
You can find the project here for testing purposes: https://github.com/Tinkerforge/master-brick/tree/master/hardware
the whole log:
lukeler@lukaspc:~/tf/master-brick/hardware$ freecad kicad-StepUp-tools.FCMacro master
FreeCAD 0.17, Libs: 0.17R13528 (Git)
Ā© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018
not a freecad file: .FCMACRO
PoM not present
FC Version 017-13528
no Links support
kicad StepUp version 7.2.2.3
tolerance on vertex applied
applying Materials to Shapes
your home path is /home/lukeler
ksu file ā€˜ksu-config.ini’ exists
materials section present
turntable section present
compound section present
docking section present
constraints section present
exporting mode section present
importing mode section present
font section present
useGridOrigin option present
3D models prefix=/home/lukeler/tf/kicad-libraries/3d/
3D models prefix2=
pcb color=0.2,0.2,0.2,darkgrey (25,25,25)
blacklist modules:
volume: 0 heigh: 0
bounding box option: 0 whitelist:
placement board @ useBaseOrigin #place board @ 0,0,0
idf_to_origin: True
last fp path:
last brd path: /home/lukeler/tf/master-brick/hardware
virtual models: addVirtual
export fusing option: nofuse #default
minimum drill size: 0.0mm
export to STEP: True
STEP exporting mode: hierarchy
Links importing mode: links_not_allowed
enable materials: True
turntable: False
compound allowed: True
docking mode: right
constraints mode: all
arg file path /home/lukeler/tf/master-brick/hardware
opening master.kicad_pcb
my file path /home/lukeler/tf/master-brick/hardware
PCB Loader
pcb thickness 1.6002mm
kicad_pcb version 4
board area [127.275589, 74.875389, 167.374571, 114.974371]
aux_axis_origin[127.325, 74.925]
2d closed path
max Length=39.99992 index=0
running time: 2sec
start cutting
cutting time 0
Shape already removed
running time: 2sec
creating hierarchy
placing board @ -147.32508,94.92488
building up pcb time 3
start adding constraints to pcb sketch
adding constraints time 0
running time: 3sec
VBO status False
ReadShapeCompoundMode status True
disabling ReadShapeCompoundMode
Capacitors_SMD/C_0805.wrl
model name C_0805
opening /home/lukeler/tf/kicad-libraries/3d/Capacitors_SMD/C_0805.step
C_0805
module Capacitors_SMD/C_0805.step
added 1 model(s)
Capacitors_SMD/C_0402.wrl
model name C_0402
opening /home/lukeler/tf/kicad-libraries/3d/Capacitors_SMD/C_0402.step
C_0402
module Capacitors_SMD/C_0402.step
added 2 model(s)
model name C_0402
C_0402
copying from cache
added 3 model(s)
model name C_0402
C_0402
copying from cache
added 4 model(s)
model name C_0402
C_0402
copying from cache
added 5 model(s)
model name C_0402
C_0402
copying from cache
added 6 model(s)
model name C_0402
C_0402
copying from cache
added 7 model(s)
model name C_0402
C_0402
copying from cache
added 8 model(s)
model name C_0402
C_0402
copying from cache
added 9 model(s)
model name C_0402
C_0402
copying from cache
added 10 model(s)
Resistors_SMD/R_0603.wrl
model name R_0603
opening /home/lukeler/tf/kicad-libraries/3d/Resistors_SMD/R_0603.step
R_0603
module Resistors_SMD/R_0603.step
added 11 model(s)
model name R_0603
R_0603
copying from cache
added 12 model(s)
Capacitors_SMD/C_0603.wrl
model name C_0603
opening /home/lukeler/tf/kicad-libraries/3d/Capacitors_SMD/C_0603.step
C_0603
module Capacitors_SMD/C_0603.step
added 13 model(s)
model name C_0603
C_0603
copying from cache
added 14 model(s)
model name C_0603
C_0603
copying from cache
added 15 model(s)
model name R_0603
R_0603
copying from cache
added 16 model(s)
model name R_0603
R_0603
copying from cache
added 17 model(s)
model name R_0603
R_0603
copying from cache
added 18 model(s)
model name R_0603
R_0603
copying from cache
added 19 model(s)
model name R_0603
R_0603
copying from cache
added 20 model(s)
model name R_0603
R_0603
copying from cache
added 21 model(s)
model name R_0603
R_0603
copying from cache
added 22 model(s)
model name R_0603
R_0603
copying from cache
added 23 model(s)
model name R_0603
R_0603
copying from cache
added 24 model(s)
model name R_0603
R_0603
copying from cache
added 25 model(s)
model name R_0603
R_0603
copying from cache
added 26 model(s)
model name C_0603
C_0603
copying from cache
added 27 model(s)
model name C_0603
C_0603
copying from cache
added 28 model(s)
model name C_0603
C_0603
copying from cache
added 29 model(s)
model name C_0603
C_0603
copying from cache
added 30 model(s)
model name C_0603
C_0603
copying from cache
added 31 model(s)
model name C_0603
C_0603
copying from cache
added 32 model(s)
model name R_0603
R_0603
copying from cache
added 33 model(s)
model name C_0805
C_0805
copying from cache
added 34 model(s)
model name C_0603
C_0603
copying from cache
added 35 model(s)
model name C_0805
C_0805
copying from cache
added 36 model(s)
model name C_0603
C_0603
copying from cache
added 37 model(s)
model name C_0805
C_0805
copying from cache
added 38 model(s)
model name R_0603
R_0603
copying from cache
added 39 model(s)
model name C_0805
C_0805
copying from cache
added 40 model(s)
model name C_0603
C_0603
copying from cache
added 41 model(s)
model name C_0603
C_0603
copying from cache
added 42 model(s)
model name C_0603
C_0603
copying from cache
added 43 model(s)
model name C_0603
C_0603
copying from cache
added 44 model(s)
model name C_0603
C_0603
copying from cache
added 45 model(s)
model name C_0603
C_0603
copying from cache
added 46 model(s)
model name C_0603
C_0603
copying from cache
added 47 model(s)
model name C_0603
C_0603
copying from cache
added 48 model(s)
model name C_0603
C_0603
copying from cache
added 49 model(s)
model name C_0603
C_0603
copying from cache
added 50 model(s)
model name C_0603
C_0603
copying from cache
added 51 model(s)
model name C_0603
C_0603
copying from cache
added 52 model(s)
model name C_0603
C_0603
copying from cache
added 53 model(s)
model name C_0603
C_0603
copying from cache
added 54 model(s)
model name C_0603
C_0603
copying from cache
added 55 model(s)
model name C_0603
C_0603
copying from cache
added 56 model(s)
model name C_0603
C_0603
copying from cache
added 57 model(s)
model name C_0805
C_0805
copying from cache
added 58 model(s)
Housing_SOT_SOD/SOT-223.wrl
model name SOT-223
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOT-223.step
SOT-223
multipart found! …
module Housing_SOT_SOD/SOT-223.step
added 59 model(s)
Housing_SOT_SOD/SOD-123.wrl
model name SOD-123
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOD-123.step
SOD-123
module Housing_SOT_SOD/SOD-123.step
added 60 model(s)
Housing_SOT_SOD/SOD323F.wrl
model name SOD323F
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOD323F.step
SOD323F
module Housing_SOT_SOD/SOD323F.step
added 61 model(s)
model name SOD323F
SOD323F
copying from cache
added 62 model(s)
model name SOD323F
SOD323F
copying from cache
added 63 model(s)
model name SOD323F
SOD323F
copying from cache
added 64 model(s)
Oscillators_SMD/3225.wrl
model name 3225
opening /home/lukeler/tf/kicad-libraries/3d/Oscillators_SMD/3225.step
3225
multipart found! …
module Oscillators_SMD/3225.step
added 65 model(s)
Housing_SOT_SOD/SOT-23-5.wrl
model name SOT-23-5
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOT-23-5.step
SOT-23-5
module Housing_SOT_SOD/SOT-23-5.step
added 66 model(s)
Housing_SOT_SOD/SOT-23-6.wrl
model name SOT-23-6
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOT-23-6.step
SOT-23-6
module Housing_SOT_SOD/SOT-23-6.step
added 67 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 68 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 69 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 70 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 71 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 72 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 73 model(s)
model name SOT-23-6
SOT-23-6
copying from cache
added 74 model(s)
Housing_SSOP/TSSOP-20.wrl
model name TSSOP-20
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SSOP/TSSOP-20.step
TSSOP-20
module Housing_SSOP/TSSOP-20.step
added 75 model(s)
Housing_SOT_SOD/SOT-563.wrl
model name SOT-563
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOT-563.step
SOT-563
multipart found! …
module Housing_SOT_SOD/SOT-563.step
added 76 model(s)
Housings_QFP/LQFP-100_14x14mm_Pitch0.5mm.wrl
model name LQFP-100_14x14mm_Pitch0.5mm
opening /home/lukeler/tf/kicad-libraries/3d/Housings_QFP/LQFP-100_14x14mm_Pitch0.5mm.step
module Housings_QFP/LQFP-100_14x14mm_Pitch0.5mm.step
added 77 model(s)
Resistors_SMD/R_4x0603.wrl
model name R_4x0603
opening /home/lukeler/tf/kicad-libraries/3d/Resistors_SMD/R_4x0603.step
R_4x0603
multipart found! …
module Resistors_SMD/R_4x0603.step
added 78 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 79 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 80 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 81 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 82 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 83 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 84 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 85 model(s)
model name R_4x0603
R_4x0603
copying from cache
added 86 model(s)
Housing_SOT_SOD/SOT-23.wrl
model name SOT-23
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOT-23.step
SOT-23
module Housing_SOT_SOD/SOT-23.step
added 87 model(s)
Connectors_TF/BrickletConn_10pin.wrl
model name BrickletConn_10pin
opening /home/lukeler/tf/kicad-libraries/3d/Connectors_TF/BrickletConn_10pin.step
BrickletConn_10pin
module Connectors_TF/BrickletConn_10pin.step
added 88 model(s)
BrickletConn_10pin
copying from cache
added 89 model(s)
BrickletConn_10pin
copying from cache
added 90 model(s)
BrickletConn_10pin
copying from cache
added 91 model(s)
Inductors/WE-CNSW-0603.wrl
model name WE-CNSW-0603
opening /home/lukeler/tf/kicad-libraries/3d/Inductors/WE-CNSW-0603.step
WE-CNSW-0603
multipart found! …
module Inductors/WE-CNSW-0603.step
added 92 model(s)
Connectors_TF/btb_btm.wrl
model name btb_btm
opening /home/lukeler/tf/kicad-libraries/3d/Connectors_TF/btb_btm.step
btb_btm
module Connectors_TF/btb_btm.step
added 93 model(s)
Connectors_TF/btb_top.wrl
model name btb_top
opening /home/lukeler/tf/kicad-libraries/3d/Connectors_TF/btb_top.step
btb_top
module Connectors_TF/btb_top.step
added 94 model(s)
model name btb_btm
btb_btm
copying from cache
added 95 model(s)
model name btb_top
btb_top
copying from cache
added 96 model(s)
Housing_SOT_SOD/SOD-128.wrl
model name SOD-128
opening /home/lukeler/tf/kicad-libraries/3d/Housing_SOT_SOD/SOD-128.step
SOD-128
multipart found! …
module Housing_SOT_SOD/SOD-128.step
added 97 model(s)
LED_SMD/D_0603_blue.wrl
model name D_0603_blue
opening /home/lukeler/tf/kicad-libraries/3d/LED_SMD/D_0603_blue.step
D_0603_blue
multipart found! …
module LED_SMD/D_0603_blue.step
added 98 model(s)
D_0603_blue
copying from cache
added 99 model(s)
D_0603_blue
copying from cache
added 100 model(s)
D_0603_blue
copying from cache
added 101 model(s)
LED_SMD/D_0603_red.wrl
model name D_0603_red
opening /home/lukeler/tf/kicad-libraries/3d/LED_SMD/D_0603_red.step
D_0603_red
multipart found! …
module LED_SMD/D_0603_red.step
added 102 model(s)
D_0603_blue
copying from cache
added 103 model(s)
Capacitors_Tantalum_SMD/Tantalum_Case-B_EIA-3528-21.wrl
model name Tantalum_Case-B_EIA-3528-21
opening /home/lukeler/tf/kicad-libraries/3d/Capacitors_Tantalum_SMD/Tantalum_Case-B_EIA-3528-21.step
module Capacitors_Tantalum_SMD/Tantalum_Case-B_EIA-3528-21.step
added 104 model(s)
Housing_special/MiniMelf.wrl
model name MiniMelf
opening /home/lukeler/tf/kicad-libraries/3d/Housing_special/MiniMelf.step
MiniMelf
multipart found! …
module Housing_special/MiniMelf.step
added 105 model(s)
model name MiniMelf
MiniMelf
copying from cache
added 106 model(s)
Connectors/MiniUSB.wrl
model name MiniUSB
opening /home/lukeler/tf/kicad-libraries/3d/Connectors/MiniUSB.step
MiniUSB
module Connectors/MiniUSB.step
added 107 model(s)
Buttons_Switches/tact_switch_bricks.wrl
model name tact_switch_bricks
opening /home/lukeler/tf/kicad-libraries/3d/Buttons_Switches/tact_switch_bricks.step
tact_switch_bricks
module Buttons_Switches/tact_switch_bricks.step
added 108 model(s)
tact_switch_bricks
copying from cache
added 109 model(s)
running time: 52sec
enabling ReadShapeCompoundMode
exporting to MCAD
hierarchy
Exception while processing file: kicad-StepUp-tools.FCMacro [global name ā€˜find_skt_in_Doc’ is not defined]
