There is a new tool for creating “real” outsets from a limited set of shapes: segments, rectangles, circles and pads (except trapezoidal or custom shaped). If you choose rounded corners, these use real arcs rather than interpolated polygons:
2024-09-19_17-42 outset rectangle
When possible (i.e. no arcs), you also get polygons back, which means you can do boolean operations on them. This means quite a few common fiddly operations in footprint drawing become more straightforward:
When possible (mostly for rectangle-based outsets), it can be asked to attempt to round outwards to some grid multiple. This can be used, for example, for rounding courtyards to the IPC-recommended 0.01mm grid rather than manually bumping things around by 0.005mm here and there.
It can also be used (with a little manual trimming of end caps) for, say, snake-shaped slots:
outset arcs chain
The ‘bounding hull’ tool still exists and remains the only way to handle arbitrary polygons (in particular ones with holes or concave corners).
