How to cure the “cvpcb” which “hangs” or gives “errors” when run. U had written these two points below:-
- In KiCAD project module, change Module and 3DShape path under preferences.
- In EEschema/SymbolEditor remove all libraries under preferences.
Now kindly. also explain, the above 1st. point: As when I click on menu > preference > the “name” and “Path” box is displayed. It shows “four names” & paths: 1. KICAD_PTEMPLATES… 2. KIGTUB 3. KISYS3DMOD 4. KISYSMOD
There is an “ADD button”, a “DELETE button” & an “OK button”. There is no “change path button”.but I suppose a path when clicked gets highlighted and selected. I hope I am on the correct box here.
Now which path to select, & which button to click, to make a change in path?
& in your 2nd. point above: When I click on “preference” then “component library” option is seen next. & when I click on that, the “list of library” box appears, which has “ADD” & “REMOVE” buttons, and also some “three paths” are shown in the lower part (“current search path”) of this dialogue box. So what to do with these 3-paths? Do I select each path and click “REMOVE” button? & then the OK button?
So, Pl. also help me remove this trouble above, as when I run “cvpcb”, the program takes a long time to open up, and usually it “hangs”, or shows errors after searching for a long time. My net connection is OK also, though not very fast at times, here in this, a bit backward country.
Thank you for giving Ur precious time to me in this regard.
- Joan_Sparky , - The above two steps I had found in your post (that thread is now closed). That temporarily stopped the hanging problem, but I did it w/o
