I’m trying to simulate a Linkwitz-Riley 24 dB/oct filter with KiCad.
After some researches i’m stuck on NgSPices Errors.
I’ve used the TL072 Spice model provided by texas instrument and i have correctly configured the pin.
I get this errors in NgSpice,
Circuit: KiCad schematic
Reducing trtol to 1 for xspice ‘A’ devices
Doing analysis at TEMP = 27,000000 and TNOM = 27,000000
Warning: singular matrix: check nodes net-c3-pad1 and net-_c3-pad1_
Note: Starting dynamic gmin stepping
Trying gmin = 1,0000E-03 Note: One successful gmin step
Trying gmin = 1,0000E-04 Note: One successful gmin step
Trying gmin = 1,0000E-05 Note: One successful gmin step
Trying gmin = 1,0000E-06 Note: One successful gmin step
Trying gmin = 1,0000E-07 Note: One successful gmin step
Trying gmin = 1,0000E-08 Note: One successful gmin step
Trying gmin = 1,0000E-09 Note: One successful gmin step
Trying gmin = 1,0000E-10 Note: One successful gmin step
Trying gmin = 1,0000E-11 Note: One successful gmin step
Trying gmin = 1,0000E-12 Note: One successful gmin step
Warning: Dynamic gmin stepping failed
Note: Starting source stepping
Supplies reduced to 0,0000% Warning: singular matrix: check nodes net-c3-pad1 and net-c3-pad1
Trying gmin = 1,0000E-02 Note: One successful gmin step
Note: One successful source step
Supplies reduced to 0,1000% Warning: singular matrix: check nodes net-c3-pad1 and net-_c3-pad1_
Supplies reduced to 0,0000% Warning: singular matrix: check nodes net-c3-pad1 and net-_c3-pad1_
Warning: source stepping failed
AC operating point failed -
Last Node Voltages
Node Last Voltage Previous Iter
net-c1-pad1 1,62715e-35 0
in 0 0
net-c2-pad1 8,15385e-45 -2,86746e-49
net-c3-pad2 1,62715e-35 1,88741e-44
net-r3-pad2 4,07693e-45 0
xu1.11 2,77446e-40 -9,43654e-45
xu1.12 1,95935e-40 1,13628e-49
xu1.6 -2,30489e-39 0
xu1.7 1,62715e-35 7,59072e-54
xu1.53 0 -5,03291e-49
xu1.54 0 -5,03291e-49
xu1.90 1,34256e-40 8,3053e-54
xu1.91 0 -4,15265e-54
xu1.92 0 -4,15265e-54
vee 0 0
vdd 0 0
xu1.99 0 -7,59072e-54
xu1.10 2,98512e-40 -9,43635e-45
xu1.9 0 0
xu1.8 1,62715e-35 0
net-c3-pad1 0 0
net-c4-pad1 0 0
output 0 0
net-r4-pad2 0 0
h.xu1.hlim#branch -3,27706e-52 0
v.xu1.vlim#branch 1,34256e-43 0
v3#branch -1,33895e-43 0
v2#branch 1,98485e-47 0
v1#branch 0 0
v.xu1.vln#branch -1,63853e-52 0
v.xu1.vlp#branch 1,63853e-52 0
v.xu1.ve#branch 1,98485e-47 0
v.xu1.vc#branch -1,98485e-47 0
v.xu1.vb#branch -2,30489e-44 0
a$poly$e.xu1.egnd#branch_1_0 -1,33965e-43 0
doAnalyses: iteration limit reached
run simulation(s) aborted
Any Help will be massively apreciated !
Thank’s in advance !
Baptiste
