Latest version keeps prompting on startup
I installed the latest version yesterday
on each start-up, Kicad keeps asking to participate and to check for updates
it was not doing that before, this is annoying beyond belief
how do I solve this ?
thanks
Application: KiCad x64 on x64
Version: 7.0.5, release build
	wxWidgets 3.2.2
	FreeType 2.12.1
	HarfBuzz 6.0.0
	FontConfig 2.14.1
	libcurl/7.88.1-DEV Schannel zlib/1.2.13
	Date: May 27 2023 02:48:13
	wxWidgets: 3.2.2 (wchar_t,wx containers)
	Boost: 1.81.0
	OCC: 7.6.3
	Curl: 7.88.1-DEV
	ngspice: 40
	KICAD_SPICE=ON
Mine is doing the same. I updated to v7 2 days ago. I have the same build
Hi probably not answer based on wording of question but maybe
Tied to this article
https://gitlab.com/kicad/code/kicad/-/merge_requests/1276
On my system UM22.04.2 with 7.0.5 I have this. Clicking on Plugin and Content Manager yields error when I disconnect my hotspot on right and brings up a list of available plugins when on.
In preferences I think you could try unchecking as in image
I did not come across as I use only custom library and Eeschema as a powerful and excellent drawing program and am amazed by the skills of others using it for it’s intended purpose.
I installed KiCad through Winget, and it installed the same, 7.0.5 version. I am on a fresh Win11 install. Likewise, I also had this issue where KiCad kept asking for participation and updates.
After starting KiCad as administrator once, it didn’t ask me again afterwards, even if I launch KiCad normally.
From that behaviour, it seems like there is an issue with a configuration file creation.
