Oh man, these look really good.
Version 0.6.2 is now available via PCM and also from the repository directly (please see the first post of this thread).
To use the corresponding small demo project (same circuit as mentioned above from the Elektor TV video for LTspice
but using ngspice
- Optional: Tools → Plugin and Content Manager → Repository → Libraries → Elektuur Style Symbol Library → Install → Apply Changes → Close → Close
- Download demo project from the repository in own folder and extract all or use File → Unarchive Project…
- Open the
*.kicad_sch
file withKiCad 6
Schematic Editor - Open the
*.wbk
file using Inspect → Simulator… → File → Open… (#8644) - Simulation → Settings… → OK (#9874)
- Simulation → Run Simulation
To use (already installed 64-bit) LTspice
instead of ngspice
, replace above:
Place → Add Text →
.tran 10
→ OK in Schematic Editor - File → Export → Netlist… → Spice → Create Netlist and Run Simulator Command
Plot Settings → Visible traces or View → Visible traces in
LTspice
, selectV(1)
andV(2)
while holding downShift
orCtrl
key
I know this is an old post, but… this depends strongly on where you are. In some places, it’s 100% not true.
First attempt at rounded octagonal pads (radius ratio is currently 25%, same like the 130 mil terminal pads were, but it almost looks like the 100 mil and 160 mil component/terminal pads weren’t actually rounded other than because of the processes then):
just loaded this library , boy thats brings me back, I think my last subscription to elektor was anout 15 years ago , nice , now just need a circuit with 20 transistors!!
While they had their own custom made dry transfers for circuit symbols, they might have used Reber/Edding R41 dry transfers for some PCB pads:
Where can I download those footprints?
The image above is from a single generated test footprint (but you should be able to copy pads and resize with context menu Properties… → Custom Shape Primitives → Polygon → Transform Primitive → Scaling factor and adjust Size X and Hole size X in General):
octagons.kicad_mod (27.1 KB)
For more footprints, see also the 2nd part of this posting:
R41!
I’m in Italy, that remembers me the old times at school and by the way, by that time Elektor was published in Italian as well
Updates and supersessions to first and following postings continued here:
