Hi, this is my first hour using Manjaro ever.
Is it possible to install Kicad 7 on Manjaro? How can I do that? Can someone give me some directions?
Thank you.
Thank you.
Last time I checked, Manjaro was using the standard Arch repos. If that is still the case, then you should be able to
$ sudo pacman -Syu kicad kicad-library kicad-library-3d
Thanks @thebig
I am not sure if I have to change a repos or something. But I am seeing Kicad 6 only.
The textual version just in case.
~/Documents/assoc-board main ?2 sudo pacman -Syu kicad kicad-library kicad-library-3d 1 ✘ 17s
[sudo] password for lheck:
:: Synchronizing package databases...
core is up to date
extra is up to date
community is up to date
multilib is up to date
error: failed retrieving file 'core.db' from mirror.ventraip.net.au : The requested URL returned error: 404
error: failed retrieving file 'extra.db' from mirror.ventraip.net.au : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.ventraip.net.au : The requested URL returned error: 404
warning: too many errors from mirror.ventraip.net.au, skipping for the remainder of this transaction
warning: kicad-6.0.11-1 is up to date -- reinstalling
warning: kicad-library-6.0.11-1 is up to date -- reinstalling
warning: kicad-library-3d-6.0.11-1 is up to date -- reinstalling
:: Starting full system upgrade...
resolving dependencies...
looking for conflicting packages...
Packages (3) kicad-6.0.11-1 kicad-library-6.0.11-1 kicad-library-3d-6.0.11-1
Total Installed Size: 5781,90 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n]
It is 7.0.1 here: Arch Linux - kicad 7.0.1-1 (x86_64)
Did not see your msg. Thanks, I could find the package with the Flatpak thanks.
Yeah, I found this page. I just could not understand how to use this, yet. I am using Manjaro since yesterday.
This has some extra steps to launch it from the CLI, which is fine but I could not launch kicad-cli yet.
Ah, found an old post of mine that solves that.
Summary so far:
kicad-cli yetI appreciate it if someone has any directions.
The goal is to install Kicad 7 and use/launch Kicad, eeschema, pcbnew, kicad-cli from the command line.
This seems relevant Arch User Repository - Manjaro
I figured out that:
Cheers!
You could also checkout the 7.0 branch and build that manually. Getting all the dependencies and configuring the build correctly might not be that trivial, however, depending on your experience with building C++ software.
It installed Kicad 6 when I did this a few days ago
You can try with this: How to build KiCad on Linux (the easy way) · Wiki · eelik-kicad / kicad · GitLab (I haven’t tested recently and not with v7)
Kicad is the only program I compile. It started because Debian was way too far behind. They do better with backports now though. Once set up, it isn’t too bad. It is the set up that can be a problem at the start though.
Oh, definitely, I just wanted to use Kicad yesterday a couple of times. This could have taken more time… or not, actually, since this was something more complex than I was expecting, haha
I use Arch and KiCad 7 packages in Arch.
With archinstall, I think there is less reason to use Manjaro, etc – vanilla Arch is now easy to install and long term will be a lot less pain to maintain than Manjaro or other wrapper distros that install a bunch of stuff that will likely not be maintained.
Oh, that’s interesting.
I found Manjaro trying to find a quick way to test the Arch package manager without having to reconfigure the whole world. But it looks like Manjaro also has some differences, especially on the available packages like Kicad 7.
But this is awesome, thanks for sharing it.
The nice thing with arch is it’s trivial to download the PKGBUILD file and then build manually:
Put the above in a directory, and then run:
makepkgpacman -U <package file>Or follow the PKGBUILD to manually build.
