Hello. I am trying to use kicad-cli from a flatpak installation. I only found this post Arch|Manjaro and Kicad 7 that barely mentions that one user was not able to do so.
Is it still not possible? Thanks in advance.
Assuming whoever packages flatpak for kicad didn’t exclude kicad-cli binary from the archive then a combination of --command=/app/path/to/kicad-cli and --filesystem=home or similar should work.
You can get a shell within the flatpak with flatpak run --command=bash org.kicad.KiCad and then poke around to find where kicad-cli is and where your files are mounted.
Thanks for your help!
Executing bash using flatpak run as you suggested made it really easy to find where the binary was mounted and now I can use it through this shell or using: flatpak run --share=network --filesystem=home:rw --command=/app/bin/kicad-cli -- --version org.kicad.KiCad
You showed how to use the cli using flatpak and how flatpak works. Thanks a lot!
