Hi there!
I just faced with the problem that some of my pads are too small relative to their hole diameter. I made some visual search and fixed some.
However I can not rely on my eyes in this case.
I tried to make a out of rules hole (1.6mm hole, 1.65 size while my design rules set to min width at 0,15mm) so it SHOULD not be passed, however it does
Is there any better way to check my pads?
Pads are not tracks, neither build with tracks, so you can not create any rule for that in Design Rule Editor. Therefore - I think - you may use build in Pcbnew Python scripting to create a simple script which may validate your pads.
To me, that is certainly a deficiency in the DRC capabilities. I believe every board vendor I have dealt width will put a job on âHoldâ if they detect insufficient annulus width.
I acknowledge that there are practical barriers to implementing such a DRC check, because occasionally we deliberately specify a hole with the same diameter as its pad. Nevertheless, a DRC check for minimum annular ring seems like a pretty fundamental feature.
Hi @Roman_Matveev, here is an example script that Iâve created to check annular ring sizes of the pads. When you run, it will simply iterate over all pads and print the locations of the pads that violate annular ring size.
from kicad.pcbnew.board import Board
def annring_size(pad):
return min(pad.size) - max(pad.drill)
MIN_AR_SIZE = .25
board = Board.from_editor()
for m in board.modules:
for pad in m.pads:
if annring_size(pad) < MIN_AR_SIZE:
print("AR violation at %s." % pad.position)
To run this script in pcbnewâs python shell, you will need my fork of kicad-python. You can find the file that contains above code in the âexamples/â folder of the repository. Let me know if you canât get it work, I will try to help.
wow, Impressively simple.
Now Iâm a little confused about Python status. I find this threadâŚ
That suggests it is in 4.x+, and I can see this promising windowâŚ
PyCrust 0.9.8 - KiCAD Python Shell
Python 2.7.10 (default, Jul 8 2015, 15:10:39)
[GCC 5.1.0] on win32
Type âhelpâ, âcopyrightâ, âcreditsâ or âlicenseâ for more information.
but paste of the code above tries to work, but gives this error
Traceback (most recent call last):
File ââ, line 1, in
ImportError: No module named kicad.pcbnew.board
Is there more than one Python, and what is different about the fork of kicad-python you mention ?
ie what can it do, the main fork cannot, and vice versa ?
Is there a timeline to merge this ?
Kicad has a python api which is automatically created from the C++ API using a tool called SWIG. This API isnât very pythonic, it feels like a c++ library and doesnât have the ease of use and flexibility of python. So, some developers decided to create a wrapper around this API, called kicad-python. I believe their aim was to create a simpler and better documented scripting interface for kicad.
Notice that kicad-python, doesnât call the C++ API directly, so it isnât a replacement of actual python API of kicad, but is a wrapper around it.
About my fork of kicad-python; it wasnât actively developed at the time I saw it, so I decided to fork it and add some features. Itâs far from complete, and I only add features as I need them.
Is it ever going to be merged to kicad? I donât know.
To be able to use above code snippet, you should download/clone mykicad-python repository and add it to python path so that interpreter can import modules;
Is this then a superset of what KiCad has ?
Trying to figure out why not to merge this ?
I think it tried to work, but I get this message on a test board
File â/KiCad_Python/kicad-python-master/kicad/pcbnew/pad.pyâ, line 34, in PadShape
RoundedRectangle = pcbnew.PAD_SHAPE_ROUNDRECT
AttributeError: âmoduleâ object has no attribute âPAD_SHAPE_ROUNDRECTâ
Sort of. But when its completed (if that ever happens) it wonât be able provide any features that is not provided by native python API.
Disclaimer: this is my opinion, I donât know what kicad developers think about the matter: Itâs yet another burden. Native python API is automatically generated so it doesnât have much development overhead. kicad-python on the other hand, should be updated every time there is a change to C++ API.
I have 4.0.2.the latest full release, of 2016. I was wary of anything less mainstream, as that may be less stable.
[quote=âhyOzdâ] Native python API is automatically generated so it doesnât have much development overhead. kicad-python on the other hand, should be updated every time there is a change to C++ API.
[/quote]
hmm.
If the same script was attempted in the main-stream version, what would that need to change to ?
That seems to work.
I added counters so it reports like this
execfile(âC:\KiCad_Python\kicad-python-master\examples\checkar_count.pyâ)
checkar_count.py Testing PCB
AR violation at (172974000, 110744000).
AR violation at (172212000, 110744000).
AR violation at (154813000, 96520000).
PADS that Pass = 49 Fails = 3
but Iâm new to Python, so could not find a way to scale the list back to mm ( /mm_ius ?), other than thisâŚ
improved the reporting, and add report actual value
# -*- coding: utf-8 -*-
# An example script to check for annular ring violations
import pcbnew
mm_ius = 1000000.0
AR_SET = 0.25
MIN_AR_SIZE = AR_SET * mm_ius
return min(pad.GetSize()) - max(pad.GetDrillSize())
def f_mm(raw):
return repr(raw/mm_ius)
board = pcbnew.GetBoard()
PassC=FailC=0
print("checkar_count.py Testing PCB for Annular Ring >= "+repr(AR_SET))
for module in board.GetModules():
for pad in module.Pads():
ARv = annring_size(pad)
if ARv < MIN_AR_SIZE:
# print("AR violation at %s." % (pad.GetPosition() / mm_ius )) Raw units, needs fixing
XYpair = pad.GetPosition()
print("AR violation of "+f_mm(ARv)+" at XY "+f_mm(XYpair[0])+","+f_mm(XYpair[1]) )
FailC = FailC+1
else:
PassC = PassC+1
print("PADS that Pass = "+repr(PassC)+" Fails = "+repr(FailC))
# execfile("C:\KiCad_Python\kicad-python-master\examples\checkar_count.py")
# checkar_count.py Testing PCB for Annular Ring >= 0.25
# AR violation of 0.1 at XY 172.974,110.744
# AR violation of 0.1 at XY 172.212,110.744
# AR violation of 0.0 at XY 154.813,96.52
# PADS that Pass = 49 Fails = 3
Hi again, EDIT: I corrected annular calculation, which has to be 1/2 the previous calculation value
Iâve added a checking also for via annulars
and added an extra on drill tool as
