Request for comments (@chschlue suggested to go ahead):
A couple of days ago, I proposed to contribute the LM5156H to the V6 repoâs. In fact, there are to very similar parts: The LM5156H and the LM51561H.
Datasheet title:
LM5156xH 2.2-MHz Wide VIN 65-V Non-synchronous Boost/SEPIC/Flyback Controller with 150°C Maximum Junction Temperature
I made the symbols and created a schematic with them. I have not yet committed the parts and I have not done the merge request yet.
The LM5156H and LM51561H are controllers for switched boost/SEPIC/Flyback DCDC converters. The difference between the LM50156H and the LM51561H is that in the latter a function called âhiccupâ is enabled. In the LM5156H this âhiccup functionâ is disabled.
The âhiccup functionâ handles the behavior of the controller after an overcurrent situation has occurred.
In the image below you can see the symbol in a schematic. The circuit in this version is non-operational, obviously, and is based on Figure 10-3 in the datasheet. I used it to test the symbol and run ERC checks.
Note that, according to the datasheet, pin 13 (PGOOD) can be left floating when not used.
Note also that the LM5156H and LM51561H are powered via pin 1 (BIAS). The naming is somewhat misleading, but it is what it is in datasheet. The Vcc pin is the output of the internal regulator.
There are two ERC messages remaining about the power pins only. The ERC errors are acceptable for the current state of this schematic.
ERC report (vr 02 apr 2021 08:45:09 CEST, Encoding UTF8)
***** Sheet /
[power_pin_not_driven]: Input Power pin not driven by any Output Power pins Severity: error
@(118,11 mm, 87,63 mm): Symbol #PWR06 [GNDS] Pin 1 [GNDS, Power input, Line]
@(120,65 mm, 72,39 mm): Symbol U1 [LM5156H] Pin 1 [BIAS, Power input, Line]
** ERC messages: 2 Errors 2 Warnings 0
The datasheet for the LM5156xH is here: https://www.ti.com/lit/ds/symlink/lm5156h.pdf
If any of you have amendments to suggest, either to the symbol or to the information I have given here, please let me know.
I will probably generate the merge request in a couple of days.
