Zooming on Large PCB's (Bug?)
For answering this question:
… I did a little experiment.
I made some selection in an existing PCB and moved that 1000mm to the right. Then I could not zoom in anymore on that moved section.
In this post, Rene wrote PCB coordinates are 32 bit integers and should go from -2148 to +2147mm
Python says:
>>> pow (2, 31)
2147483648.0
Bobc added that “Weird stuff” starts to happen once you go over a meter. An experiment confirms I can not zoom in on a 1206 resistor if it’s X-coordinate is larger then about 1074mm, which is suspiciously close to half of the 2147 max coordinate.
So how important is this considered to be?
@smart1 Did you encounter further problems with your big PCB?
Mike Harrison (Mikes Electric Stuff) makes big PCB’s also, I remember one of his youtube video’s where he talks about having difficulty in finding a PCB manufacturer (in the UK) that could make his PCB’s. I thing those PCB’s were also over 2 meters long.
My KiCad version is the regular 5.1.6 which should be bug free
Application: KiCad
Version: 5.1.6-c6e7f7d~87~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 5.4.0-42-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.5.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
[Edit:] Added KiCad version, tought about this while trying to find Mike’s video, Eelik beat me to it in asking :slight_smile:
KiCad version? Have you tried with 5.99?
