The right-side connectors contain a much tighter pitch-interval than the left-side connectors. There is not enough space for connecting the thermal spokes to pad 2+5 on the right side (without violating the drc-clearance rules).
possible solutions:
zone parameter: clearance value smaller
zone parameter: minimum width smaller
zone parameter: thermal spoke width smaller
pad parameter (for v7): doubleclick the unconnected GND-pads → get Pad properties dialog → panel "clearance overrides and settings–>set Spoke angle == 0°. This change builds horicontal spokes on the relevant pads (there seems to be enough place left+right of the connector-footprint). Be aware: if you later update the footprint from library this change will be overwritten and lost
routing: manually route the connection to the GND-pads
global drc-constrains: reduce copper clearance value
as a remark: Solely relying on the automatic connection of GND-pads (without knowing the advantages and risks of this behaviour) is a little bit dangerous. If you get unlucky the automatic GND-connection with a zone-fill only connects with a small piece of copper, or with a very long copper-loop.
