Before I report this as a bug, when look at the About window the Platform field doesn’t report my system properly. Here is my OS information from my system about window (screenshot because windows is arbitrary about when you can select text to put in the clipboard…):
Here is the copied version information from KiCad:
Application: kicad
Version: (5.0.0-rc3-dev), release build
wxWidgets 3.0.3
libcurl/7.54.1 OpenSSL/1.0.2l zlib/1.2.11 libssh2/1.8.0 nghttp2/1.23.1 librtmp/2.3
wxWidgets: 3.0.3 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.60.0
Curl: 7.54.1
Compiler: GCC 7.1.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Before I submit this as a bug report on launchpad, I want to check that this really is an error. Should that Platform field be the host machine, or is it the machine that the binaries were compiled on?
What about other platforms, all you non windows users out there. Assuming you didn’t build your own package, what does your version info say about the platform vs. the platform that you are running it on?
I don’t want to submit the bug report that I’ve written if this is a misunderstanding on my part of what the value of that field should me. (i.e. I’d rather look dumb to y’all, than waste the developer’s time correcting my misunderstanding.)
