I’m trying to get to grips with the Kicad simulator. I successfully simulated a simple op-amp circuit using a TL071 symbol. I then changed this to a TL072 symbol and I can no longer get it to work - I used the alternative node sequence to change the pins but still nothing, the simulation window says -
warning, can’t find model vm
Circuit: KiCad schematic
Error on line 9 :
u2 vout net-c1-pad2 0 vm vp tl072
Unable to find definition of model vm
Error: circuit not parsed.
I’m using the same spice model as I used for the first (successful) simulation (the model for a LF356) but this seems to be telling me that it can’t find a model for the op-amp.
the TL072 is a multiple unit symbol (one unit for each amplifier and one for the power pins), so you’ll need to do some extra work to simulate it. Basically you’ll need to make a wrapper model that connects each unit to the relevant pins in the underlying amplifier model.
