Standard plot has black background that’s not suitable if you have to copy in a text. And in my opinion it’s not the best way to show data in general.
How can I set background to white, and of course text to black?
KiCad 5.1.5 in openSuse Linux
Application: KiCad
Version: 5.1.5-5.1.5, release build
wxWidgets 3.0.3
libcurl/7.60.0 OpenSSL/1.1.0i zlib/1.2.11 libidn2/2.2.0 libpsl/0.20.1 (+libidn2/2.0.4) libssh/0.8.7/openssl/zlib nghttp2/1.39.2
Platform: Linux 4.12.14-lp151.28.40-default x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.3 (wchar_t,STL containers,compatible with 2.8) GTK+ 2.24
Boost: 1.66.0
Curl: 7.60.0
Compiler: GCC 7.4.0 with C++ ABI 1011
Clearly obvious to you, but I would have missed it without eelik’s edit, which he added when I was halfway my post.
I had a look through the settins of KiCad’s integrated spice simulator, but I could also not find anything relevant.
I was curious about a wishlist for simulation features, but am not even sure whether to look at gitlab or github for the moment.
So for now I only see 2 workarounds. Either save a picture (or .svg?) from within the simulator and post process with a suitable program (simple command line program to invert colors?) or: Spice Simulator / Simulation / Show Spice Netlist and then copy / paste into another simulator to redo the simulation, or save the netlist directly from Eeschema / Tools / Generate Netlist File / Spice
In nightly build this feature (switch black/white background) is already available. Then I suppose there is a way to do in 5.1.5.
And I found here in page 11
Example:
set color0 = white ; background color
set color1 = blue ; text and grid color
that sound similar to what I need. I tried to insert these in “text box” in my schematic without any effect. Not sure I understood well but it seems they are “command” .
May be you’re right but I don’t see anything else to plot in simulation but voltage and current.
ngspice in KiCAD and ngspice stand-alone are two different things.
ngspice plotting in KiCAD/Eeschema is exclusively handled by Eeschema only. I do not know of any color selection switch available in 5.1.5. Standalone ngspice plotting is switched off. Thus the ngspice manuals with their chapters and rules about plotting are not valid.
As paulvdh said, there is a way to use standalone ngspice from within Eeschema. Please have a look at http://ngspice.sourceforge.net/ngspice-eeschema.html#external for some hints about the procedure. Then you will have all the ngspice commands available for plotting.
The next ngspice release, ngspice-32, due early April, will have full color capability for background, grid/text and graphs.
The output file name ‘gpp’ is arbitrary. Gnuplot offers a white background. Without the locale setting, and not being in the US, gnuplot may fail opening.
Just updated to 5.1.8 and white background of simulation plot is still unavailable. Or I missed it.
Any hint to obtain white background in stable release?
5.1.x releases are bugfix releases, no new features.
The nightly builds are daily development “releases” which will lead to the next stable x.y version which at this time will be 6.0. So all new features which are now available in the nightly builds will be in 6.0 but not earlier.
I think it was for rc1, but the history shows that we shouldn’t hold our breaths, and even after rc1 the final release can take several months. But of course this time it may be different, and if people test and report bugs diligently it will be sooner.
I seldom use the simulation (preferring LTspice) but, on the few occasions when I do use it, I save the Image and use an external program to Invert the colors… That gives me something I can print on paper…
