Could someone give a “high level” explanation of the meaning of this, and what an “Assertion” is in the context of KiCad?
I haven’t been able to easily figure it out from a dictionary or a quick look at the source code, and would be thankful if someone could give me a hint to better understand how it works.
You would use an assertion for something that you think will always be true, but you want an error if it’s not. For example you could assert that a particular constraint is always set to a certain value. If it gets overridden in a way that you don’t expect, you’ll get a DRC error.
Ignore this if it is an unhelpful comparison, but this maps to the programming concept of an assertion, except you’re writing an assertion about your board design rather than a programmer writing an assertion about their code.
