I started this effort with KiCAD v6, installed from Ubuntu’s own repository. Then I updated to v8 from KiCAD’s PPA. That fixed my opamps (yay!), but not the pots.
My goal is AC analysis for audio filters, but here’s about the simplest thing I could come up with that shows the problem and still does something interesting.
Dismissing the error message on the left and trying an AC simulation anyway, gives this in the terminal at lower left:
List of plots available:
Current const Constant values (constants)
Compatibility modes selected: ps lt a
Warning: unknown .probe parameter p(c1),
.probe p(c1) will be ignored!
Warning: unknown .probe parameter p(v1),
.probe p(v1) will be ignored!
Warning: unknown .probe parameter p(c2),
.probe p(c2) will be ignored!
Circuit: KiCad schematic
Warning: Model issue on line 2 :
.model __rv1 potentiometer( r=10k ) ...
Unknown model type potentiometer - ignored
Error on line 9 :
arv1 net-_c1-pad2_ out 0 __rv1
MIF-ERROR - unable to find definition of model __rv1
Error on line 9 :
Error: circuit not parsed.
Error: vector frequency not found!
This is after setting the pot’s simulation model:
In my actual circuit with 6 pots, every one of them has this same problem. I also want to have some switches, which don’t work yet either, but I can fudge that for now with manual wiring changes.
I can fudge the pots too, with parameterized resistors, and that seems to work…until I try to tune them. Play with the fader and watch the plot change. Seems the tuner doesn’t support parameters??? Only direct component values? Not so good when I have multi-gang pots that have to keep their tracking.
I would expect the example above to produce this as-is, using the default wiper position of 0.5, but with a single tuning fader from 0 to 1 instead of two faders with actual resistances:
So like the title says, “What am I doing wrong?” “Why does the pot not work like that?”
Or, “What am I missing?”
TIA
