After creating a pcb, I use the Export to step file option and then
import into FreeCAD for reference in making an enclosure.
The step file only has position information where there is a edge or hole. I would like to place
holes with the footprint editor that will not be in the gerbers but can be used
in FreeCAD.
In the footprint editor I have tried adding a NPTH hole, setting Copper:None, Technical layers:Dwgs.User and making the Hole size X match Size X:
But I get this message:
- Error: the pad is not on a copper layer and has a hole
For NPTH pad, set pad size value to pad drill value,
if you do no want this pad plotted in gerber files.
If I set Copper:All with pad size and drill size the same, the gerber has the hole.
Maybe there is another way to put some type of reference on the footprint that can be
exported in the step file?
Application: Pcbnew
Version: 5.1.5+dfsg1-2~bpo10+1, release build
wxWidgets 3.0.4
libcurl/7.64.0 OpenSSL/1.1.1c zlib/1.2.11 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) libssh2/1.8.0 nghttp2/1.36.0 librtmp/2.3
Platform: Linux 4.19.0-6-amd64 x86_64, 64 bit, Little endian, wxGTK
Boost: 1.67.0
OpenCASCADE Technology: 7.3.0
Curl: 7.64.0
Compiler: GCC 8.3.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=OFF
KICAD_USE_OCC=ON
KICAD_SPICE=ON
