I’m working on the layout of the PCB and I need to use the via holes.
How can I use them?
How do I connect the via hole with the trace under the first layer (working in the second layer)?
Does it exist a tutorial about this argument?
thank you
Yes
So lets add a few vias. Activate the routing tool (hotkey
x). Click onpad 2ofR2(The GND pad ofR2). Pressvto add a via to your cursor and move your mouse around. Notice that you know have a via at the cursor which is followed by a trace back to your starting position.
from here:
thanks for your replay.
Now I have the necessity to put four mechanical holes (not via, but for fixing the PCB to our machine) in the angles of the PCB. Does it exist a command to realize them?
you can either add NPTH directly in PCBnew or add them via eeschema and import them.
I personally like capturing things like this (and logo’s) in eeschema
the holes can be found under the mounting hole footprint library
