Hello guys,
I am trying to simulate the I-V characteristics using sweep analysis, unfortunately I can’t change the horizontal axis from the source voltage to the diode voltage, could I ask you for help?
Thank you
Hello guys,
Thank you
Not a spice user but what you want (I think) is a I, V characteristic i.e. voltage as a function of current.
I would remove R1 and make V1 into a current source.
It makes sense, unfortunately it doesn’t work, but thanks for the effort ![]()
I would still prefer to have the voltage on the diode as a variable.
Its been a long time but I think your sweep analysis assumes a linear function for the diode (not sure).
This feature is not (yet?) supported by the KiCads-ngspice interface.
You might want to create an issue (to be put on the wishlist) at Issues · KiCad / KiCad Source Code / kicad · GitLab.
OK, thank you for information and thank you for your´s simulation tutorials.
I have created ab issue at Simulation: Allow plotting of data versus another solution vector (including user defined signals) (#17822) · Issues · KiCad / KiCad Source Code / kicad · GitLab .
