Use of esource
Bonjour la communauté,
Je suis nouveau dans Kicad et dans la communauté. J’ai des soucis avec l’utilisation du symbole esource pour la simulation d’une source dépendante de tension.
Je ne sais pas comment connecter le symbole au reste du réseau et je ne sais pas non plus comment remplir les propriétés.
Pouvez-vous me guider?
MOD EDIT:
Please translate to English. You can have both versions in case you feel something may be lost in the translation.
Hello Community, I’m new to Kicad and to the community. I’m having trouble with using the esource symbol for simulating a voltage-dependent source. I don’t know how to connect the symbol to the rest of the network, and I also don’t know how to fill in the properties. Can you guide me?
Have a look in the KiCad demos folder under simulation. There you will find a project called “v_i_sources” that may be of use in your learning.
Merci pour votre attention, mais le fichier ne présente que les sources indépendantes!
You can replace any of the sources in the sheet with either an ESOURCE if you want a voltage-dependent voltage source or a GSOURCE if you was a voltage-dependent current source.
Both of these symbols are available in the KiCad Simulation_SPICE library that comes with the software install.
The input to the ESOURCE is another voltage source or a arbitrary source measured in volts. The SPICE model in KiCad allows you to specify the gain (2 means 1V in = 2V out)
