Update PCB from schematic (Not Responding)
Thanks for your feedback. Yes, I have saved the schematic. I am trying now checking the 3 boxes of options as you mentioned. It’s still the same but I will wait for a few minutes since I read in another topic that they waited for 30 mins for the update to finish. Is this normal? I have experimented other ways and waited (even let it run overnight) but still the same, it does not finish or gets stuck.
The update should take a few seconds unless the schematic is huge.
How many components are there?
What OS and KiCad version?
Parts count is around 65. I am using Windows 10 and Kicad ver. is 5.1.10.
That should update the pcb in just a few seconds at most.
There is a chance your install got
corrupted.
Looking at the error msgs closer, I think you have a schematic problem. Annotations should be double digits, not hundreds.
Have you run eeschema ERC?
I uninstalled and installed a lesser version, 5.1.9. I reannotate the schematic so it is not in the hundreds. I also ran eeschema ERC with warnings. It is still the same.
Please note I have tried making a test schematic of 2 parts and it can proceed and load in PCB without any problem. I ran ERC on this with same warnings as my current project.
Hmm? I have used 3 digit annotations without any issues.
Because this doesn’t happen to others, we can only try to guess. It would be more productive if you could zip the project and share it here, if possible.
These long numbers in your info area look weird:
It also looks as if some numbers are erased in the first two lines (Second line has a partial characters, and they do not end in quotation marks).
With other lines there is also text missing from the info screen:
Your whole screenshot is also light grey. I assume this is because that screen did not have focus when you made the screenshot. Usually screen grabbers have a way around this.
Zipping the project and uploading it here would be best for analysis.
As an automated anti-spam measure new users do not have rights to upload files. According to your profile:
You have now accumulated 38 minutes of viewing time. That may be just enough to be able to upload files.
Thanks for your feedback. Apologies, I intentionally cut off those part of the message. It my first time, just being cautious I guess. :slight_smile: Here is the full message;
At the bottom of the message it says it has 0 warnings/error and netlist update successful. But when I click Update PCB, that when it gets stuck.
Sorry, I don’t think I can share the project due to confidentiality.
I don’t think I can upload the files also since I tried posting 2 screenshots on my previous post but it did not allow me to.
This forum uses discourse.
Here is some info on the “trust levels” and what you can do to “earn trust” so you can upload files.
Is this the only project you are having trouble with (May suggest a damaged project) or do other projects also give trouble (Which suggests something with your KiCad installation)?
You can experiment a bit with the “LoPower2.zip” file in this old thread. It’s a simple but complete project.
Just delete the PCB, and then try to port the info from Eeschema to Pcbnew again.
There are no confidentiality issues with that project.
Hello all and to @paulvdh especially !
I am happy that this old project of mine is serving a useful purpose to the community. Please enjoy!
Been a long time since visiting here, and have moved on to other things. But, these sensors are still in use!
All the best,
Mark
Could you untick the “Infos” box, despite the name it doesn’t give us any information here. It’s more probably that KiCad tries to change something. Make the dialog taller that all lines fit into the view if possible.
here it is…
Thank you for this. I will check and will give you an update.
That’s never going to work.
Those messages are several pages of text together.
There is a save button in the lower right corner though to save them to a text file.
Maybe you can already upoad files now, if not, you can just copy & paste the text in a post here.
below is from the report file…
Info: Processing component “U604:/6152A487/612A18C2:Globics:DFN1x1mm_0.55mmp_4L”.
Info: Processing component “C314:/611577D6/6123938E:Globics:C_0201_0603Metric”.
Info: Processing component “C309:/611577D6/61179C6B:Globics:C_0201_0603Metric”.
Info: Processing component “C209:/610B5580/611E0D41:Globics:C_0201_0603Metric”.
Info: Processing component “C315:/611577D6/61172663:Globics:C_0402_1005Metric”.
Info: Processing component “U203:/610B5580/610D1A80:Globics:TSOT-23-6”.
Info: Processing component “C316:/611577D6/6116C8BF:Globics:C_0402_1005Metric”.
Info: Processing component “C317:/611577D6/6115D8D3:Globics:C_0402_1005Metric”.
Info: Processing component “U202:/610B5580/610D0A57:Globics:DFN1x1mm_0.55mmp_4L”.
Info: Processing component “C318:/611577D6/611A46E6:Globics:C_0201_0603Metric”.
Info: Processing component “U607:/6152A487/6110AB39:Globics:LGA-12_2x2mm_P0.5mm”.
Info: Processing component “C207:/610B5580/6115AC48:Globics:C_0402_1005Metric”.
Info: Processing component “U204:/610B5580/610CFA31:Globics:SOT-23-5”.
Info: Processing component “U603:/6152A487/61227E0E:Globics:FBP1x1mm_4P”.
Info: Processing component “C216:/610B5580/61122E94:Globics:C_0201_0603Metric”.
Info: Processing component “C215:/610B5580/61121A0F:Globics:C_0201_0603Metric”.
Info: Processing component “C301:/611577D6/6137EAB3:Globics:C_0201_0603Metric”.
Info: Processing component “U602:/6152A487/6125BC9B:Globics:WSON-8-1EP_6x5mm_P1.27mm_EP3.4x4mm”.
Info: Processing component “C302:/611577D6/613879CE:Globics:C_0201_0603Metric”.
Info: Processing component “C214:/610B5580/610FBE7E:Globics:C_0201_0603Metric”.
Info: Processing component “C303:/611577D6/612570DE:Globics:C_0201_0603Metric”.
Info: Processing component “U601:/6152A487/610E5EB4:Globics:WLP-4_0.83x0.83mm_P0.4mm”.
Info: Processing component “C304:/611577D6/6128268B:Globics:C_0201_0603Metric”.
Info: Processing component “Q401:/614868A1/613CA6AD:Globics:DFN1006_3”.
Info: Processing component “D101:/610F0A6B:Globics:DFN1610_2L”.
Info: Processing component “L602:/6152A487/6122ADCD:Globics:L_LBMF1608”.
Info: Processing component “R510:/6148DBE7/617E1C87:Globics:R_0201_0603Metric”.
Info: Processing component “NT301:/611577D6/6125E8A5:NetTie:NetTie-2_SMD_Pad0.5mm”.
Info: Processing component “NT601:/6152A487/6125191D:NetTie:NetTie-2_SMD_Pad0.5mm”.
Info: Processing component “R509:/6148DBE7/617FB0D6:Globics:R_0201_0603Metric”.
Info: Processing component “NT602:/6152A487/61252D67:NetTie:NetTie-2_SMD_Pad0.5mm”.
Info: Processing component “NT603:/6152A487/61252975:NetTie:NetTie-2_SMD_Pad0.5mm”.
Info: Processing component “R508:/6148DBE7/6179754F:Globics:R_0201_0603Metric”.
Info: Processing component “Q201:/610B5580/6112DC45:Globics:DFN1006_3”.
Info: Processing component “C208:/610B5580/61172C13:Globics:C_0402_1005Metric”.
Info: Processing component “R507:/6148DBE7/61797542:Globics:R_0201_0603Metric”.
Info: Processing component “U606:/6152A487/610F7F99:Globics:BMP280_GMP102”.
Info: Processing component “U206:/610B5580/6122B10E:Globics:FBP1x1mm_4P”.
Info: Processing component “C310:/611577D6/6117CF75:Globics:C_0201_0603Metric”.
Info: Processing component “C211:/610B5580/610E5F67:Globics:C_0402_1005Metric”.
Info: Processing component “C311:/611577D6/61258EC2:Globics:C_0201_0603Metric”.
Info: Processing component “U205:/610B5580/6122C3B6:Globics:FBP1x1mm_4P”.
Info: Processing component “C312:/611577D6/61179652:Globics:C_0201_0603Metric”.
Info: Processing component “C210:/610B5580/610FCED6:Globics:C_0402_1005Metric”.
Info: Processing component “C313:/611577D6/611E33C8:Globics:C_0201_0603Metric”.
Info: Processing component “C402:/614868A1/614A5CBA:Globics:C_0201_0603Metric”.
Info: Processing component “Y302:/611577D6/6115DFBF:Globics:Crystal_SMD__2Pin_3.2x1.5mm”.
Info: Processing component “C607:/6152A487/6115E61C:Globics:C_0201_0603Metric”.
Info: Processing component “TP513:/6148DBE7/61778727:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C201:/610B5580/610D8337:Globics:C_0402_1005Metric”.
Info: Processing component “C608:/6152A487/61161C61:Globics:C_0201_0603Metric”.
Info: Processing component “C609:/6152A487/612F2F28:Globics:C_0201_0603Metric”.
Info: Processing component “TP512:/6148DBE7/61797520:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C610:/6152A487/610FB77D:Globics:C_0201_0603Metric”.
Info: Processing component “U608:/6152A487/6126B2FA:Globics:HVSON-8-1EP_3x3mm_P0.65mm_EP1.6x2.4mm”.
Info: Processing component “C401:/614868A1/614A6299:Globics:C_0201_0603Metric”.
Info: Processing component “C202:/610B5580/610D5BCA:Globics:C_0201_0603Metric”.
Info: Processing component “C403:/614868A1/6149E607:Globics:C_0201_0603Metric”.
Info: Processing component “TP518:/6148DBE7/61778745:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C206:/610B5580/6113E534:Globics:C_0201_0603Metric”.
Info: Processing component “C404:/614868A1/613E0052:Globics:C_0201_0603Metric”.
Info: Processing component “C501:/6148DBE7/617EFACB:Globics:C_0201_0603Metric”.
Info: Processing component “C601:/6152A487/61267236:Globics:C_0201_0603Metric”.
Info: Processing component “C502:/6148DBE7/617F7556:Globics:C_0201_0603Metric”.
Info: Processing component “TP517:/6148DBE7/6177873F:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C205:/610B5580/6113331F:Globics:C_0201_0603Metric”.
Info: Processing component “J401:/614868A1/6149521F:Globics:ZIF_CON_2Rows-15Pins_P0.60mm_Horizontal”.
Info: Processing component “TP516:/6148DBE7/61778739:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C213:/610B5580/610FBE78:Globics:C_0201_0603Metric”.
Info: Processing component “C305:/611577D6/61330762:Globics:C_0201_0603Metric”.
Info: Processing component “U501:/6148DBE7/617D9B7D:Globics:USPN-6_1.3x1.3mm_P0.45mm”.
Info: Processing component “C306:/611577D6/6129ED68:Globics:C_0201_0603Metric”.
Info: Processing component “C307:/611577D6/612A3F50:Globics:C_0201_0603Metric”.
Info: Processing component “U301:/611577D6/611579B3:Globics:WLCSP94_3.544x3.607mm_0.35mmp”.
Info: Processing component “C308:/611577D6/612AB5F4:Globics:C_0201_0603Metric”.
Info: Processing component “C212:/610B5580/610E69B9:Globics:C_0201_0603Metric”.
Info: Processing component “U605:/6152A487/611558C7:Globics:LGA-14_3x2.5mm_P0.5mm”.
Info: Processing component “C606:/6152A487/6115E60E:Globics:C_0201_0603Metric”.
Info: Processing component “D601:/6152A487/611ED477:Globics:DFN1006_2”.
Info: Processing component “C602:/6152A487/610F59E4:Globics:C_0201_0603Metric”.
Info: Processing component “C204:/610B5580/614D8F8E:Globics:C_0201_0603Metric”.
Info: Processing component “C603:/6152A487/610F5EB3:Globics:C_0201_0603Metric”.
Info: Processing component “TP515:/6148DBE7/61778733:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “Y301:/611577D6/61253A6E:Globics:Crystal_SMD_2016-4Pin_2.0x1.6mm”.
Info: Processing component “C604:/6152A487/612B3636:Globics:C_0201_0603Metric”.
Info: Processing component “C203:/610B5580/614C265B:Globics:C_0201_0603Metric”.
Info: Processing component “C605:/6152A487/612BEC60:Globics:C_0201_0603Metric”.
Info: Processing component “TP514:/6148DBE7/6177872D:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “U201:/610B5580/610CC2EC:Globics:SOT-23-5”.
Info: Processing component “TP509:/6148DBE7/6179750E:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “L201:/610B5580/61147BD5:Globics:L_0603_1608Metric”.
Info: Processing component “TP302:/611577D6/611F7079:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “L301:/611577D6/61356B0D:Globics:L_0201_0603Metric”.
Info: Processing component “TP507:/6148DBE7/61797502:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C611:/6152A487/610FBF5A:Globics:C_0201_0603Metric”.
Info: Processing component “TP511:/6148DBE7/6179751A:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C612:/6152A487/612F9C59:Globics:C_0201_0603Metric”.
Info: Processing component “C613:/6152A487/611BF3E4:Globics:C_0402_1005Metric”.
Info: Processing component “TP510:/6148DBE7/61797514:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C614:/6152A487/611AB1B3:Globics:C_0402_1005Metric”.
Info: Processing component “C615:/6152A487/61114519:Globics:C_0201_0603Metric”.
Info: Processing component “J602:/6152A487/611CCAF8:Globics:GTH01C_ECG_PLATE”.
Info: Processing component “C616:/6152A487/61113156:Globics:C_0201_0603Metric”.
Info: Processing component “C617:/6152A487/61113163:Globics:C_0201_0603Metric”.
Info: Processing component “TP508:/6148DBE7/61797508:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “C618:/6152A487/61343574:Globics:C_0201_0603Metric”.
Info: Processing component “L302:/611577D6/61355808:Globics:L_LBMF1608”.
Info: Processing component “D102:/610E97D0:Globics:DFN1610_2L”.
Info: Processing component “D201:/610B5580/61148C66:Globics:D_SOD-523”.
Info: Processing component “TP506:/6148DBE7/6179F46C:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “D401:/614868A1/613E751C:Globics:D_SOD-523”.
Info: Processing component “D501:/6148DBE7/6179F4A5:Globics:DFN1006_2”.
Info: Processing component “J106:/61146C6E:Globics:TestPoint_Pad_D2.0mm”.
Info: Processing component “R511:/6148DBE7/6178387D:Globics:R_0201_0603Metric”.
Info: Processing component “D602:/6152A487/611F38E8:Globics:DFN1006_2”.
Info: Processing component “TP502:/6148DBE7/6179F454:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “J101:/61145A12:Globics:GTH01C_POS_BAT”.
Info: Processing component “J102:/61144410:Globics:GTH01C_POS_BAT”.
Info: Processing component “TP501:/6148DBE7/6179F44E:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “J103:/6126B437:Globics:TestPoint_Pad_1.8x3.3mm”.
Info: Processing component “J104:/6126BD5B:Globics:TestPoint_Pad_1.8x3.3mm”.
Info: Processing component “TP307:/611577D6/6119FA7B:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “J105:/611461AA:Globics:TestPoint_Pad_D2.0mm”.
Info: Processing component “L403:/614868A1/61746EE2:Globics:GEARBOX_AG21”.
Info: Processing component “TP306:/611577D6/6119F2E3:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “TP503:/6148DBE7/6179F45A:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “J402:/614868A1/613D0B3D:Globics:VIBRA_CON_P1.27mm_TH”.
Info: Processing component “TP305:/611577D6/61193424:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “J501:/6148DBE7/6179F448:Globics:PUSHER_S0.7mm_P1.9mm”.
Info: Processing component “J502:/6148DBE7/617974FC:Globics:PUSHER_S0.7mm_P1.9mm”.
Info: Processing component “TP304:/611577D6/61193223:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “J503:/6148DBE7/61778721:Globics:PUSHER_S0.7mm_P1.9mm”.
Info: Processing component “J601:/6152A487/6131C017:Globics:PPG_CON_9pin_P0.7mm”.
Info: Processing component “TP303:/611577D6/61191B85:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “TP301:/611577D6/611F486B:Globics:TestPoint_Pad_D1.0mm”.
Info: Processing component “R501:/6148DBE7/6179F48E:Globics:R_0201_0603Metric”.
Info: Processing component “R302:/611577D6/611E75B3:Globics:R_0201_0603Metric”.
Info: Processing component “R303:/611577D6/611CB83E:Globics:R_0201_0603Metric”.
Info: Processing component “R404:/614868A1/613CF785:Globics:R_0201_0603Metric”.
Info: Processing component “R304:/611577D6/611CECE6:Globics:R_0201_0603Metric”.
Info: Processing component “R305:/611577D6/612897BF:Globics:R_0201_0603Metric”.
Info: Processing component “R403:/614868A1/613D6F49:Globics:R_0402_1005Metric”.
Info: Processing component “R401:/614868A1/614A0E36:Globics:R_0201_0603Metric”.
Info: Processing component “R402:/614868A1/614A782D:Globics:R_0201_0603Metric”.
Info: Processing component “L601:/6152A487/611BC3ED:Globics:L_LBMF1608”.
Info: Processing component “D502:/6148DBE7/617C1D28:Globics:DFN1006_2”.
Info: Processing component “L303:/611577D6/612A7A78:Globics:L_0201_0603Metric”.
Info: Processing component “L304:/611577D6/612AB601:Globics:L_0201_0603Metric”.
Info: Processing component “SW501:/6148DBE7/617BB894:Globics:SSCM110100”.
Info: Processing component “L305:/611577D6/612B3542:Globics:L_0201_0603Metric”.
Info: Processing component “AE301:/611577D6/61260DF3:Globics:ANT_LA31H2450-A27_3.2x1.6mm”.
Info: Processing component “L306:/611577D6/6115C583:Globics:L_LBMF1608”.
Info: Processing component “L401:/614868A1/61298684:Globics:GEARBOX_AG22”.
Info: Processing component “R512:/6148DBE7/61783E09:Globics:R_0201_0603Metric”.
Info: Processing component “L402:/614868A1/617453A7:Globics:GEARBOX_AG21”.
Info: Processing component “TP505:/6148DBE7/6179F466:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “R211:/610B5580/6112DC52:Globics:R_0201_0603Metric”.
Info: Processing component “R301:/611577D6/611EF96C:Globics:R_0201_0603Metric”.
Info: Processing component “D503:/6148DBE7/617CD115:Globics:DFN1006_2”.
Info: Processing component “TP504:/6148DBE7/6179F460:Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”.
Info: Processing component “D504:/6148DBE7/61797559:Globics:DFN1006_2”.
Info: Processing component “D505:/6148DBE7/61786393:Globics:DFN1006_2”.
Info: Processing component “R210:/610B5580/610EDECE:Globics:R_0201_0603Metric”.
Info: Processing component “R202:/610B5580/614D8F7F:Globics:R_0201_0603Metric”.
Info: Processing component “R506:/6148DBE7/617CD10B:Globics:R_0201_0603Metric”.
Info: Processing component “R203:/610B5580/610D43C7:Globics:R_0402_1005Metric”.
Info: Processing component “R204:/610B5580/614BEA62:Globics:R_0402_1005Metric”.
Info: Processing component “R205:/610B5580/614D8F87:Globics:R_0201_0603Metric”.
Info: Processing component “R206:/610B5580/61165C49:Globics:R_0201_0603Metric”.
Info: Processing component “R504:/6148DBE7/617CD0FE:Globics:R_0201_0603Metric”.
Info: Processing component “R207:/610B5580/611DF624:Globics:R_0201_0603Metric”.
Info: Processing component “R208:/610B5580/61166FA0:Globics:R_0201_0603Metric”.
Info: Processing component “R503:/6148DBE7/617C1D11:Globics:R_0201_0603Metric”.
Info: Processing component “R209:/610B5580/61100E99:Globics:R_0201_0603Metric”.
Info: Processing component “R201:/610B5580/614BA69B:Globics:R_0201_0603Metric”.
Info: Processing component “R502:/6148DBE7/6179F49B:Globics:R_0201_0603Metric”.
Info: Processing component “R505:/6148DBE7/617C1D1E:Globics:R_0201_0603Metric”.
Add L401 (footprint “Globics:GEARBOX_AG22”).
Add L306 (footprint “Globics:L_LBMF1608”).
Add R203 (footprint “Globics:R_0402_1005Metric”).
Add C311 (footprint “Globics:C_0201_0603Metric”).
Add C310 (footprint “Globics:C_0201_0603Metric”).
Add C309 (footprint “Globics:C_0201_0603Metric”).
Add C308 (footprint “Globics:C_0201_0603Metric”).
Add C307 (footprint “Globics:C_0201_0603Metric”).
Add C306 (footprint “Globics:C_0201_0603Metric”).
Add C305 (footprint “Globics:C_0201_0603Metric”).
Add C304 (footprint “Globics:C_0201_0603Metric”).
Add L402 (footprint “Globics:GEARBOX_AG21”).
Add L403 (footprint “Globics:GEARBOX_AG21”).
Add L601 (footprint “Globics:L_LBMF1608”).
Add L602 (footprint “Globics:L_LBMF1608”).
Add NT301 (footprint “NetTie:NetTie-2_SMD_Pad0.5mm”).
Add NT601 (footprint “NetTie:NetTie-2_SMD_Pad0.5mm”).
Add NT602 (footprint “NetTie:NetTie-2_SMD_Pad0.5mm”).
Add NT603 (footprint “NetTie:NetTie-2_SMD_Pad0.5mm”).
Add Q201 (footprint “Globics:DFN1006_3”).
Add Q401 (footprint “Globics:DFN1006_3”).
Add R201 (footprint “Globics:R_0201_0603Metric”).
Add C208 (footprint “Globics:C_0402_1005Metric”).
Add C617 (footprint “Globics:C_0201_0603Metric”).
Add C214 (footprint “Globics:C_0201_0603Metric”).
Add AE301 (footprint “Globics:ANT_LA31H2450-A27_3.2x1.6mm”).
Add C201 (footprint “Globics:C_0402_1005Metric”).
Add C202 (footprint “Globics:C_0201_0603Metric”).
Add C203 (footprint “Globics:C_0201_0603Metric”).
Add C204 (footprint “Globics:C_0201_0603Metric”).
Add C205 (footprint “Globics:C_0201_0603Metric”).
Add C206 (footprint “Globics:C_0201_0603Metric”).
Add C207 (footprint “Globics:C_0402_1005Metric”).
Add C303 (footprint “Globics:C_0201_0603Metric”).
Add C209 (footprint “Globics:C_0201_0603Metric”).
Add C210 (footprint “Globics:C_0402_1005Metric”).
Add C211 (footprint “Globics:C_0402_1005Metric”).
Add C212 (footprint “Globics:C_0201_0603Metric”).
Add C213 (footprint “Globics:C_0201_0603Metric”).
Add C618 (footprint “Globics:C_0201_0603Metric”).
Add C215 (footprint “Globics:C_0201_0603Metric”).
Add C216 (footprint “Globics:C_0201_0603Metric”).
Add C301 (footprint “Globics:C_0201_0603Metric”).
Add C302 (footprint “Globics:C_0201_0603Metric”).
Add J401 (footprint “Globics:ZIF_CON_2Rows-15Pins_P0.60mm_Horizontal”).
Add D504 (footprint “Globics:DFN1006_2”).
Add D505 (footprint “Globics:DFN1006_2”).
Add D601 (footprint “Globics:DFN1006_2”).
Add D602 (footprint “Globics:DFN1006_2”).
Add J101 (footprint “Globics:GTH01C_POS_BAT”).
Add J102 (footprint “Globics:GTH01C_POS_BAT”).
Add J103 (footprint “Globics:TestPoint_Pad_1.8x3.3mm”).
Add R401 (footprint “Globics:R_0201_0603Metric”).
Add J105 (footprint “Globics:TestPoint_Pad_D2.0mm”).
Add J106 (footprint “Globics:TestPoint_Pad_D2.0mm”).
Add D503 (footprint “Globics:DFN1006_2”).
Add J402 (footprint “Globics:VIBRA_CON_P1.27mm_TH”).
Add J501 (footprint “Globics:PUSHER_S0.7mm_P1.9mm”).
Add J502 (footprint “Globics:PUSHER_S0.7mm_P1.9mm”).
Add J503 (footprint “Globics:PUSHER_S0.7mm_P1.9mm”).
Add J601 (footprint “Globics:PPG_CON_9pin_P0.7mm”).
Add J602 (footprint “Globics:GTH01C_ECG_PLATE”).
Add L201 (footprint “Globics:L_0603_1608Metric”).
Add L301 (footprint “Globics:L_0201_0603Metric”).
Add L302 (footprint “Globics:L_LBMF1608”).
Add L303 (footprint “Globics:L_0201_0603Metric”).
Add R302 (footprint “Globics:R_0201_0603Metric”).
Add L304 (footprint “Globics:L_0201_0603Metric”).
Add R204 (footprint “Globics:R_0402_1005Metric”).
Add R205 (footprint “Globics:R_0201_0603Metric”).
Add R206 (footprint “Globics:R_0201_0603Metric”).
Add R207 (footprint “Globics:R_0201_0603Metric”).
Add R208 (footprint “Globics:R_0201_0603Metric”).
Add R209 (footprint “Globics:R_0201_0603Metric”).
Add R210 (footprint “Globics:R_0201_0603Metric”).
Add R211 (footprint “Globics:R_0201_0603Metric”).
Add R301 (footprint “Globics:R_0201_0603Metric”).
Add R202 (footprint “Globics:R_0201_0603Metric”).
Add R303 (footprint “Globics:R_0201_0603Metric”).
Add R304 (footprint “Globics:R_0201_0603Metric”).
Add R305 (footprint “Globics:R_0201_0603Metric”).
Add J104 (footprint “Globics:TestPoint_Pad_1.8x3.3mm”).
Add D101 (footprint “Globics:DFN1610_2L”).
Add D102 (footprint “Globics:DFN1610_2L”).
Add D201 (footprint “Globics:D_SOD-523”).
Add D401 (footprint “Globics:D_SOD-523”).
Add D501 (footprint “Globics:DFN1006_2”).
Add D502 (footprint “Globics:DFN1006_2”).
Add L305 (footprint “Globics:L_0201_0603Metric”).
Add TP501 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP518 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP502 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP517 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP503 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP516 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP504 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP505 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP306 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add TP506 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP514 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP307 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add TP507 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP508 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP513 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP509 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP512 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add TP510 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add U206 (footprint “Globics:FBP1x1mm_4P”).
Add U602 (footprint “Globics:WSON-8-1EP_6x5mm_P1.27mm_EP3.4x4mm”).
Add R509 (footprint “Globics:R_0201_0603Metric”).
Add U601 (footprint “Globics:WLP-4_0.83x0.83mm_P0.4mm”).
Add U606 (footprint “Globics:BMP280_GMP102”).
Add R505 (footprint “Globics:R_0201_0603Metric”).
Add U608 (footprint “Globics:HVSON-8-1EP_3x3mm_P0.65mm_EP1.6x2.4mm”).
Add TP511 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add R502 (footprint “Globics:R_0201_0603Metric”).
Add U603 (footprint “Globics:FBP1x1mm_4P”).
Add R402 (footprint “Globics:R_0201_0603Metric”).
Add U607 (footprint “Globics:LGA-12_2x2mm_P0.5mm”).
Add R507 (footprint “Globics:R_0201_0603Metric”).
Add Y302 (footprint “Globics:Crystal_SMD__2Pin_3.2x1.5mm”).
Add R503 (footprint “Globics:R_0201_0603Metric”).
Add R510 (footprint “Globics:R_0201_0603Metric”).
Add R404 (footprint “Globics:R_0201_0603Metric”).
Add R504 (footprint “Globics:R_0201_0603Metric”).
Add U605 (footprint “Globics:LGA-14_3x2.5mm_P0.5mm”).
Add R506 (footprint “Globics:R_0201_0603Metric”).
Add R403 (footprint “Globics:R_0402_1005Metric”).
Add U604 (footprint “Globics:DFN1x1mm_0.55mmp_4L”).
Add Y301 (footprint “Globics:Crystal_SMD_2016-4Pin_2.0x1.6mm”).
Add R501 (footprint “Globics:R_0201_0603Metric”).
Add TP515 (footprint “Globics:TestPoint_THTPad_D1.5mm_Drill0.7mm”).
Add U201 (footprint “Globics:SOT-23-5”).
Add C605 (footprint “Globics:C_0201_0603Metric”).
Add C401 (footprint “Globics:C_0201_0603Metric”).
Add C402 (footprint “Globics:C_0201_0603Metric”).
Add C403 (footprint “Globics:C_0201_0603Metric”).
Add C404 (footprint “Globics:C_0201_0603Metric”).
Add C501 (footprint “Globics:C_0201_0603Metric”).
Add C502 (footprint “Globics:C_0201_0603Metric”).
Add C601 (footprint “Globics:C_0201_0603Metric”).
Add C602 (footprint “Globics:C_0201_0603Metric”).
Add C312 (footprint “Globics:C_0201_0603Metric”).
Add C604 (footprint “Globics:C_0201_0603Metric”).
Add C318 (footprint “Globics:C_0201_0603Metric”).
Add C606 (footprint “Globics:C_0201_0603Metric”).
Add C607 (footprint “Globics:C_0201_0603Metric”).
Add C608 (footprint “Globics:C_0201_0603Metric”).
Add C609 (footprint “Globics:C_0201_0603Metric”).
Add C610 (footprint “Globics:C_0201_0603Metric”).
Add C611 (footprint “Globics:C_0201_0603Metric”).
Add C612 (footprint “Globics:C_0201_0603Metric”).
Add C613 (footprint “Globics:C_0402_1005Metric”).
Add C614 (footprint “Globics:C_0402_1005Metric”).
Add C615 (footprint “Globics:C_0201_0603Metric”).
Add TP303 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add R511 (footprint “Globics:R_0201_0603Metric”).
Add U501 (footprint “Globics:USPN-6_1.3x1.3mm_P0.45mm”).
Add R512 (footprint “Globics:R_0201_0603Metric”).
Add U301 (footprint “Globics:WLCSP94_3.544x3.607mm_0.35mmp”).
Add SW501 (footprint “Globics:SSCM110100”).
Add R508 (footprint “Globics:R_0201_0603Metric”).
Add TP301 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add U205 (footprint “Globics:FBP1x1mm_4P”).
Add TP302 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add U204 (footprint “Globics:SOT-23-5”).
Add C616 (footprint “Globics:C_0201_0603Metric”).
Add TP304 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add U203 (footprint “Globics:TSOT-23-6”).
Add TP305 (footprint “Globics:TestPoint_Pad_D1.0mm”).
Add U202 (footprint “Globics:DFN1x1mm_0.55mmp_4L”).
Add C603 (footprint “Globics:C_0201_0603Metric”).
Add C313 (footprint “Globics:C_0201_0603Metric”).
Add C314 (footprint “Globics:C_0201_0603Metric”).
Add C315 (footprint “Globics:C_0402_1005Metric”).
Add C316 (footprint “Globics:C_0402_1005Metric”).
Add C317 (footprint “Globics:C_0402_1005Metric”).
I checked my design and found a discrepancy with pin count between schematic symbol and footprint (an exposed pad of an IC which did not have a pin on the symbol). I have corrected it but still has the same issue. I will continue to check my design and post my findings.
If a footprint has more pins then the schematic symbol they’re just left unconnected. This does not generate an error or warning.
If the schematic symbol has pin numbers which are not in the Footprint, then it does generate error messages for that.
Have you checked with another project yet? This may indicate whether your problem is with your schematic, or with KiCad itself.
