I’m trying to layout a board where there are two isolated circuits. One side is Signal Ground using the “normal” ground symbol.
I’ve then created a symbol named GNDiso. I find both grounds are made common when I go the the PCB.
I suspect the library symbol properities has something to do with it but I can’t figure it out. I tried unchecking the “Define as power symbol” with no luck.
I assume I could just make the GNDiso a label but this would reduce the readability of the schematic.
Short answer:
Simplest is to copy an existing power symbol and then make both the “Name” and the (hidden) text of the pin the same in the Symbol Editor. The label text is the same as the text for the hidden pin, while the name of the component is the visual text.
the pin must also have an “electrical type” of “Power Input”.
Have you made something that looks good on the schematic, or have you also actually verified in Pcbnew that the net labels are created and works as expected?
