Hi;
How can i change the number of turns in the primary and secondary windings?
Hi;
The schematic symbol for the transformers is just a symbol that says “there is a transformer here”. Your winding count should probably be specified as a ratio in the value field.
In Proteus and Eagle, i can do that easily. I have to edit the component and change the electric properties (Coupling ratio; resistances of primary and secondary, inductances,…) so when i run the simulation so i can see results as if it’ll be in practice.
Sorry, I didn’t notice the simulation tag for this thread. Ignore what I said, I know nothing about using the simulation.
The simulation tag was not there when you answered. (The question was incomplete.) I added it after the last answer by @Nabil_Dakhli
