Topology mismatch not allowing Repeat Layout function
Hi all! I’m trying to use the new ‘Repeat Layout’ function but am running into a topology error. I’m not sure what is causing this error. For context:
  1. I am trying to repeat this circuit seven times, and have 7 identical sheets:
  1. I have the layout complete for the first instance, and have generated the Multichannel Rule Areas:
  1. I have all other instances in my layout, also within Multichannel Rule Areas (only showing two for reference):
  2. When I go to repeat the layout, I am met with the ‘Topology Mismatch’ status, and KiCAD tells me 0 rule areas were copied:
I have used the repeat layout function in this same project and ran into no issues. I’m not really sure what to do from here, and I’m sure there’s a simple fix that I am missing. Any help would be appreciated and I can also send the project files if needed. Thanks!
Version info:
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) UHD Graphics, 4.6.0 - Build 32.0.101.5972
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_CA
Enc: UTF-8
Num: 1,234.5
Read this first: Multichannel layout - tool not pasting the reference layout
Somebody else had a problem with “topology”.
EDIT: nah, it was this one: Multi-Channel: I'm getting a "topology mismatch" status when attempting to repeat layout
Thanks for the response! I read that post before posting, but unfortunately, that solution didn’t work for my project.
Please try the most recent “Testing” build. Over 100 bugs have been fixed since the 9.0.0 release
There’s no fix for the “topology” in the nightly builds yet, but we are working on it. In the meanwhile, could you share a minimum version of the project showing the issue? It would help us make sure the fix is working correctly :slight_smile:
T.
topology_fix.zip (124.8 KB)
Here’s the section that isn’t working, thanks!
Thanks for the suggestion, I’ll try this
Hey, was there any update on this fix?
Yes. The connections in your reference channel are different than in the channels you’re trying to repeat layout to:
  • reference has C1036-2 connected to CHASSIS_GND and C1035-2 to GND
  • targets have both the Cxxx-2 (the 1206 cap) and the counterpart of C1035-2 connected to GND
These are not topologically identical circuits, hence the topology mismatch error. Reconnect C1036-2 to GND and it should work. In the future releases we’ll make the error messages more verbose allowing to track down such issues more quickly.
T.
Great, I hadn’t realized that! Thank you for the help.
