To understand pulse symbol benefit
How to understand and use kicad pulse symbol, of value td, tr, tw, per, so on ?
Is this a simulation question?
EDIT: I’ve moved this to simulation for now at least.
https://ngspice.sourceforge.io/docs/ngspice-manual.pdf
Seeing that they’re in the “pspice” or “Simulation SPICE” libraries should give a hint.
OK
got most of it but not all
especially if try to produce simulated graph of the current by the pulse across a device resistor
see at Help simulate DPDT / H-bridge across R(motor load equivalent)
