TI AMC1200 PSPICE file incompatibility with KiCad
I have downloaded the PSPICE file for the AMC1200 from the TI website. I get the following error message when I try to use it with KiCad 8.0.8
Please will you assist.
Note: Compatibility modes selected: ps lt a
Circuit: KiCad schematic
Warning: Model issue on line 443 :
.model q_nmos_out_l1 nmos level=1 l=10u w=100u kp= 1.942393387325625e …
unrecognized parameter (rds) - ignored
Warning: Model issue on line 450 :
.model q_pmos_out_l1 pmos level=1 l=10u w=100u kp= 1.942393387325625e …
Thank You
Fred Philpott
There are no error messages, but some warning messages.
The ngspice MOS model does not support the RDS parameter. Typically this is not a critical issue.
I might consider adding it to ngspice, as it is available in PSPICE as well.
Thank you for your prompt response. I have it working and the results are what I expect so it isn’t affecting my design. I was just concerned in case I was missing something.
