Hi all, I have setup some info in the Page Settings in the Schematic Editor, how do I copy/sync with the PCB Page Settings?
I have found a few pages that say about the fields, like using ${REVISION} (for example) in the PCB settings panel, but it didn’t work. Also tried SCHEMATIC_REVISION from another page but that didn’t work.
I’m probably using the wrong terms searching for it, sorry if this is super obvious!
My memory is a bit fuzzy on this but I believe the principle is that variables for each editor are only for that editor, and can’t be “migrated”. However you can define project wide variables which apply to both.
