Does any one has subcircuit file of LM386?
I have designed the subcircuit using the reference http://www.circuitbasics.com/wp-content/uploads/2015/04/LM386-Datasheet.pdf
But I did not get proper result.
Google is your friend, Check for “lm386 spice model”
Thank you for your reply I will go through it
Compared to the “NO-FRILLS LM386 MODEL” by Dave Dilatush from 5/30/95, there is an improved Ngspice compatible model developed for EasyEDA. It is demonstrated here:
https://easyeda.com/example/Demonstrating_the_EasyEDA_LM386_spice_subckt_model-pgoiAgM4m
with a direct link to the subcircuit file here:
