Strange simulation result
I’m using KiCAD 9.0rc2 to simulate a power inverter.
Version: 9.0.0-rc2-288-g9083c9e6ab-dirty, release build
	wxWidgets 3.2.6
	FreeType 2.13.3
	HarfBuzz 10.2.0
	FontConfig 2.15.0
	libcurl/8.11.1 GnuTLS/3.8.8 zlib/1.3.1 brotli/1.1.0 zstd/1.5.6 libidn2/2.3.7 libpsl/0.21.2 libssh2/1.11.1 nghttp2/1.64.0 ngtcp2/1.9.1 nghttp3/1.6.0 librtmp/2.3 OpenLDAP/2.6.9
Platform: Devuan GNU/Linux 6 (excalibur/ceres), 64 bit, Little endian, wxGTK, X11, , x11
OpenGL: AMD, AMD Radeon RX 570 Series (radeonsi, polaris10, LLVM 19.1.4, DRM 3.59, 6.12.9-amd64), 4.6 (Compatibility Profile) Mesa 24.2.8-1
	Date: Jan 30 2025 12:09:11
	wxWidgets: 3.2.6 (wchar_t,wx containers) GTK+ 3.24
	Boost: 1.74.0
	OCC: 7.8.1
	Curl: 8.11.1
	ngspice: 44
	Compiler: GCC 14.2.0 with C++ ABI 1019
	KICAD_IPC_API=ON
Locale:
	Lang: fr_FR
	Enc: UTF-8
	Num: 1 234,5
My schematic is:
sim_onduleur.pdf (200.0 KB)
Simulation runs as expected if I remove R8 and add R13 from netlist (pure resistive load). Currents in Q1 and Q2 are around 9 A when mosfets are switched on (expected values).
Now, I’m trying to simulate circuit with R8 and without R13. Currents in mosfets are greater than 60 A. In some configurations, currents are greater than 150 A! Thus, Q1 and Q2 should be destroyed as their maximum power are exceeded.
On real circuit, Q1 and Q2 stay cold.
I have tried to add RC snubber on transformer (C6/R17) without success. I suspect an issue with IDH02 model but I’m not sure. My design doesn’t seem to be faulty as it runs as expected. But why does simulation return this result ?
Regards,
JB
PS: netlist and models
sim_onduleur.cir (1.9 KB)
OptiMOS3_250V.lib (93.3 KB)
SCS_G5_1200V_v1_IDH.lib (13.5 KB)
standard_bjt.lib (306.4 KB)
stth1r02.lib (150 Bytes)
transformateur.lib (831 Bytes)
I’ve just seen that pdf output doesn’t respect “do not simulate” flag. Of course, simulation is done without C6 and R17. And only one of R8 and R13 is used in simulation. not both.
Would you mind to also publish the Eeschema file *.kicad_sch?
Of Course.
sim_onduleur.kicad_sch (129.2 KB)
