Stepup error "not fused ('union') in single part ..."
I’m trying to convert a pcb to mcad step with stepup.
To generate the part to have 1:1 scale do:
  • select all
  • part -> boolean -> union
DRQ127.stp (1.1 MB)
When try generate the mcad get this error:
“3D STEP model DRQ127 is NOT fused (‘union’) in a single part …”
How can do to fix?
Thanks
your part is not fused correctly… (always reload your part after a fusion to check it)
in some cases FC doesn’t make a union of parts because of OCC kernel
as pointed out in the StepUp starter guide here there are some tips to fuse correctly objects in
FreeCAD
http://forum.freecadweb.org/viewtopic.php?t=8451#p69489
In this case the problem is in your model which is done as open faces and not as solid
The union operation only works well on solids.
Unfortunately not all manufacturers will offer real MCAD models
possible solution:
  1. create yourself a 3D model
  2. get the model from a different source, checking if the model is a solid part
  3. search for a 3D of a similar part
Note: the topic should be "StepUp error message: ‘not fused (‘union’) in single part…’ "
it is not a bug but a warning message to help users
Maurice
