How do I probe across two nodes of a circuit, i.e., measuring voltage between two nodes.
For example, I want to see AC waveform between two nodes.
Thanks!
Thanks!
I do not know if that is possible…Even as I keep trying and waiting for others to suggest something useful, how about adding an opamp with -ve feedback to give just the difference at the output?
Will it work for Transient analysis?
Following simple circuit does not work:
I get the “Singular Matrix” error when simulating.
Please post the “exact” error message.
What about adding two 1GOhm resistors inside of the subcircuit between in+ in- and GND?
Please try using a negative feedback
Regards
Rahul
Yep, adding the two 1Gohm resistors as you suggested seems to do the trick! Thanks!
