IMPORTANT! Updated: 04/04/2023 4:43 P.M.PST
SPICE Models LM78xx & LM79xx Series
I examined the node connections and values of the 317/337
original SPICE models and discovered that in both instances the
‘ground/adjust’ pin was connected to only one other node in the
SPICE coding. The other end of it was the open external designated
connection of the 3-pin subcircuit definition code.
I simply renamed that node to one higher number
in the model hierarchy and then added the
two necessary resistors connected as a standard 317/337
voltage adjustable SPICE model and achieved what
we have all wanted for 30 years.
LM7809 and LM7909 SPICE
As well as being able to emulate the entire LM78xx and LM79xx series.
Also, they are internally variable 3-pin versions of the LM317/LM337
reducing the need for the 4 extra external resistors on a densely populated PC Board.
This SPICE Modeling Method creates both
Positive and Negative
Internally Adjustable 3-Pin Regulators
to provide the full range of LM78xx and LM79cxx
Voltage Regulators.
Prior to this implementation there were only
±12VDC and ±15VDC Regulator SPICE Models Available.
Since these LM78xx and LM79xx SPICE Models are completely based upon the
LM317/LM337 Design both RADJ and RBIAS can be varied according the established formulas for same.
Where:
External Resistor R1 = Internal Resistor RBIAS
External Resistor R2 = Internal Resistor RADJ
LM317/LM337 Formulae:
Vout = 1.25V x (1 + RADJ/RBIAS)
Therefore:
RADJ = RBIAS x ((Vout - 1.25V)/1.25V)
9 VOLT EXAMPLE:
Vout = 1.25V x (1 + 1365/220) = 9V
Therefore:
RADJ = 220 x ((9V - 1.25V)/1.25V) = 1365
NOTE: Due to differences in the LM79xx Negative Voltage Regulator SPICE Model
it is necessary to manually adjust RADJ value to achieve desired voltage output.
EXAMPLE:
LM7809 RADJ = 1365
LM7909 RADJ = 1465
These are fully functional Spice Models of the LM7809 (+9V) & LM7909 (-9V) Voltage Regulators based upon the LM317 & LM337 Spice.
By adjusting the value of the “RADJ” resistor one can simulate the entire LM78xx & LM79xx series of Voltage Regulators.
Filename: LM7809.CIR
========== BEGIN SPICE MODEL ==========
* LM7809
* SPICE (Simulation Program with Integrated Circuit Emphasis)
* SUBCIRCUIT
* Connections: In Gnd Out
.SUBCKT LM7809 1 2 3
RBIAS 40 3 220
RADJ 2 40 1365
D4 4 3 D_Z6V0
D3 5 6 D_Z6V3
D2 7 1 D_Z6V3
D1 3 8 D_Z6V3
QT26 1 10 9 Q_NPN 20.0
QT25 1 11 10 Q_NPN 2.0
QT24_2 13 12 5 Q_NPN 0.1
QT24 13 12 14 Q_NPN 0.1
QT23 17 16 15 Q_NPN 1.0
QT21 19 18 3 Q_NPN 0.1
QT19 21 3 20 Q_NPN 1.0
QT17 23 3 22 Q_NPN 0.1
QT13 1 25 24 Q_NPN 0.1
QT11 16 27 26 Q_NPN 0.1
QT7 30 29 28 Q_NPN 0.1
QT5 29 31 3 Q_NPN 0.1
QT3 33 31 32 Q_NPN 0.1
QT22_2 17 17 1 Q_PNP 1.0
QT22 16 17 1 Q_PNP 1.0
QT20 3 19 16 Q_PNP 0.1
QT18 21 21 16 Q_PNP 0.1
QT16 23 21 16 Q_PNP 0.1
QT15 3 23 25 Q_PNP 0.1
QT12 3 24 16 Q_PNP 0.1
QT9 27 30 34 Q_PNP 0.1
QT6 3 29 34 Q_PNP 0.1
QT14 25 33 35 Q_PNP 0.1
QT10 16 33 36 Q_PNP 0.1
QT8 34 33 37 Q_PNP 0.1
QT4 31 33 38 Q_PNP 0.1
QT2 33 33 39 Q_PNP 0.1
R27 4 40 50
R26 9 3 100M
R25 9 14 2
R24 5 14 160
R23 7 6 18K
R22 10 3 160
R21 12 13 400
R20 18 13 13K
R19 16 11 370
R18 15 10 130
R17 16 12 12K
C3 19 18 5P
R16 16 19 6.7K
R15 20 22 2.4K
R14 22 4 12K
C2 23 4 30P
C1 23 3 30P
R13 24 3 5.1K
R12 26 3 72
R11 27 3 5.8K
R10 28 3 4.1K
R9 32 3 180
R8 34 30 12.4K
R7 31 29 130
R6 8 31 100K
R5 1 35 5.6K
R4 1 36 82
R3 1 37 190
R2 1 38 310
R1 1 39 310
JT1 1 3 8 J_N
.MODEL D_Z6V0 D(IS=10F N=1.04 BV=6.0 IBV=1M CJO = 1P TT = 10p)
.MODEL D_Z6V3 D(IS=10F N=1.04 BV=6.3 IBV=1M CJO = 1P TT = 10p)
.MODEL Q_NPN NPN(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=90)
.MODEL Q_PNP PNP(IS=10F NF=1.04 NR=1.04 BF=50 CJC=1P CJE=2P TF=10P TR=1N VAF=45)
.MODEL J_N NJF(VTO=-7)
.ENDS
========== END SPICE MODEL ==========
Filename: LM7909.CIR
* LM7909
* SUBCIRCUIT
* Connections: Gnd
* | In
* | | Out
.SUBCKT LM7909 2 1 3
RBIAS 55 3 220
RADJ 2 55 1465
D6 14 15 D_6V3_0
D5 3 17 D_1
D4 3 19 D_1
D3 12 13 D_0
D2 16 3 D_6V3_1
D1 3 18 D_2
QTU37 20 22 21 Q_PNP_1 1.000
QTU36 21 27 26 Q_PNP_1 1.000
QTU35 1 25 7 Q_PNP_0 1.000
QTU34 30 3 13 Q_PNP_2 0.090
QTU33 4 5 3 Q_PNP_0 1.000
QTU32 6 5 3 Q_PNP_0 1.000
QTU31 7 5 3 Q_PNP_0 1.000
QTU30 28 5 3 Q_PNP_0 1.000
QTU29 5 11 3 Q_PNP_0 1.000
QTU28 29 11 3 Q_PNP_0 1.000
QTU27 31 8 32 Q_PNP_0 1.000
QTU26 8 8 32 Q_PNP_0 1.000
QTU25 8 8 9 Q_PNP_0 1.000
QTU24 10 8 9 Q_PNP_0 1.000
QTU23 3 47 27 Q_NPN_0 1.000
QTU22 3 45 44 Q_NPN_1 10.00
QTU21 3 46 45 Q_NPN_2 3.000
QTU20 33 34 35 Q_NPN_0 1.000
QTU19 33 34 14 Q_NPN_0 1.000
QTU17 27 37 20 Q_NPN_0 1.000
QTU16 22 36 1 Q_NPN_0 1.000
QTU15 21 37 38 Q_NPN_0 1.000
QTU14 8 37 39 Q_NPN_0 1.000
QTU13 17 37 40 Q_NPN_0 1.000
QTU12 30 31 17 Q_NPN_0 1.000
QTU11 31 10 17 Q_NPN_0 1.000
QTU10 10 10 17 Q_NPN_0 1.000
QTU9 21 4 1 Q_NPN_0 1.000
QTU8 4 6 1 Q_NPN_0 1.000
QTU7 6 23 1 Q_NPN_0 1.000
QTU6 24 25 41 Q_NPN_0 1.000
QTU5 25 42 1 Q_NPN_0 1.000
QTU4 29 42 43 Q_NPN_0 1.000
QTU3 5 28 29 Q_NPN_0 1.000
QTU2 19 48 32 Q_NPN_0 1.000
QTU1 19 49 9 Q_NPN_0 1.000
R37 36 33 15K
R36 16 15 18K
R35 15 14 100K
R34 35 50 10
R33 14 35 150
R32 51 34 12K
C5 33 34 2P
R31 51 33 390
R30 21 51 12K
C4 22 36 5P
R29 21 22 6.8K
R28 20 1 500
R27 40 39 6K
R26 38 1 2.4K
R25 40 1 500
R24 50 1 40M
R23 4 52 20K
R22 52 1 4K
R21 23 52 8K
R20 41 1 4.2K
R19 7 24 12K
R18 43 1 600
R17 42 25 270
R16 37 42 1K
R15 28 37 4K
R14 11 5 750
R13 5 18 60K
R12 18 16 100K
R11 44 50 200M
R10 45 44 250
R9 21 46 100
R8 31 53 5K
C3 53 30 15P
C2 48 30 15P
R7 3 26 220
R6 30 47 2K
R5 54 47 800
C1 3 54 25P
R4 55 19 60
R3 48 12 20K
R2 19 48 2K
R1 19 49 2K
.MODEL D_6V3_0 D(IS=10F N=1.04 BV=6.3 IBV=1M CJO=1P TT=10p)
.MODEL D_6V3_1 D(IS=10F N=1.04 BV=6.3 IBV=1M CJO=1P TT=10p)
.MODEL D_0 D(IS=1F N=1.14 CJO=1P TT=10p)
.MODEL D_1 D(IS=1F N=1.16 CJO=1P TT=10p)
.MODEL D_2 D(IS=1F N=1.16 CJO=1P TT=10p)
.MODEL Q_PNP_0 PNP(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=45)
.MODEL Q_PNP_1 PNP(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=45)
.MODEL Q_PNP_2 PNP(IS=10F NF=1.14 NR=1.14 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=45)
.MODEL Q_NPN_0 NPN(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=90)
.MODEL Q_NPN_1 NPN(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=90)
.MODEL Q_NPN_2 NPN(IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P TF=10P TR=1N VAF=90)
.ENDS
