[solved] PCBnew white lines from unconnected parts
Hello everyone,
is there a way to toggle the white lines in the placement of the PCBnew? Its getting very confusing with many parts.
Its called “ratsnest” under view
It is possible to hide the “rastnests”, with the right panel, in second tab. Take a look at the discussion in this thread:
There are two options which control this behaviour. There’s a “Hide Board Ratnest” on the left toolbar, and a “Show Local Ratnest” on the right toolbar.
When “Hide Board Ratnest” is toggled ON, the “Show Local Ratnest” button on the right can be used to selective hide the Ratnest for components (you can select one or many).
When “Hide Board Ratnest” is toggled OFF, the “Show Local Ratnest” button on the right can be used to selective show the Ratnest for components (you can select one or many).
Play with both options and see how it works for you.
