[SOLVED] Cannot find pspice library even if it loads its content
I’m learning how to simulate in Kicad and I’m following some tutorial.
For example I placed an pspice:OPAMP symbol, then I selected the model I downloaded for a TL072:
As you can see it successfully loaded the content of the library file.
But when I run the simulation it says it cannot find the library!
immagine
How is it possible?
What should I do in order to fix this?
I set the compatibility mode to ps:
Compatibility modes selected: ps
I’m using this Kicad version:
Application: KiCad Schematic Editor
Version: 6.0.10-86aedd382b~118~ubuntu22.04.1, release build
	wxWidgets 3.0.5
	libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.13
Platform: Linux 5.15.0-60-generic x86_64, 64 bit, Little endian, wxGTK, ubuntu, x11
	Date: Dec 18 2022 19:39:39
	wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.24
	Boost: 1.74.0
	OCC: 7.5.2
	Curl: 7.86.0
	ngspice: 36
	Compiler: GCC 11.3.0 with C++ ABI 1016
	KICAD_USE_OCC=ON
	KICAD_SPICE=ON
Check the file and directory permissions first.
$ ls -l
totale 28
drwxrwxr-x  2 mark mark 4096 lug 25  2022 3d
-rw-rw-r--  1 mark mark  972 ott  8  2020 esp32-poe.kicad_mod
drwxrwxr-x 14 mark mark 4096 feb 24  2021 footprint
drwxrwxr-x  2 mark mark 4096 lug 25  2022 library
drwxrwxr-x  2 mark mark 4096 apr 25  2021 logo
drwxrwxr-x  2 mark mark 4096 feb 10 11:10 pspice
drwxrwxr-x  4 mark mark 4096 feb 16  2022 scripts
and
$ ls -l
totale 4
-rw-rw-r-- 1 mark mark 1153 feb 10 11:10 tl072.lib
They seem ok to me.
But it they were wrong, it could not have loaded the content as shown in the first picture, could it?
Anyway, I tried to set them to 777 but nothing changed.
please post the ngspice netlist here:
Eeschema → Export → netlist → Spice → Export netlist
File attached, thanks.
test-log.cir (284 Bytes)
Problem found.
I had to change the path of the file using an absolute path.
For me it’s a bug: using the select button it should retrieve the path it needs!
The offending line is
.include "MyProject/Development/Kicad/pspice/op184.lib"
It includes a relative path starting with MyProject.
As ngspice is a shared library, the relative path starts with the location of the caller, the eeschema executable. Can you follow this path, from eeschema until op184.lib is found?
O.k., just an overlap of posts. You may consider opening a bug report at Issues · KiCad / KiCad Source Code / kicad · GitLab.
