[SOLVED] Accelerated graphics crash with multi monitor set up
ok, test on screens at home. Same problem. I made a dump file now. I will PM you a link from “sprend”
Ahhhh… I don’t know how so send PM here in kicad forum.
But here are the link of the dump file. Only for MAREKR! All other please don’t download at this time. btw it’s 1.2GB
EDIT by JMK:
Hi @Laserclaes I removed the link as Marekr has a copy and RaptorUK has shown how to Message (PM).
Click on marekr’s Avatar then click Message . . .
EDIT by JMK to remove @Laserclaes project link.
Yea you should do a direct message next time.
Anyway I downloaded a copy. Will look at it later tonight.
This may be related to this issue
I don’t see the Message button. Firefox?
New users can’t send PMs, but can receive them. So @marekr or whoever wants to contact a new user directly should initiate the conversation
Uninstall from your PC, any audio crapware (it’s almost malware) called Nahimic. It’s common for ASUS and MSI, both also sometimes pre-built PCs too.
That software tries to inject itself almost maliciously into every software on your PC, in the process it ■■■■■ up OpenGL because it’s horrible incompetent software. It doesn’t even have any business interacting with OpenGL but it does.
This is a known issue affecting many programs beyond kicad.
WOW!!! I think you are right. Did a fast test and kill the processes and it seams to work. Have to digg a little diper. But Thx so far :slight_smile:
This will be some hacking… :wink:
https://www.reddit.com/r/MSI_Gaming/comments/l45fnj/guide_how_to_uninstall_nahimic_completely_from/?rdt=62071
marekr already posted he has downloaded your file. So you can both edit your post to remove the link, and remove it from that “spread” website :slight_smile:
@Laserclaes
You have almost read enough to self promote yourself to “Basic”, which will allow you to message.
Left click your forum name then left click your forum name in the newly opened box then click “Summary”.
Compare your stats to these in the FAQ link here.
All you now need to do now is open and read a few posts in three more topics,
I also removed both links in this thread to your dump file.
A change was pushed to both nighies and 7.0 testing builds that’ll attempt to use a 'hidden method" in the nahimic malware that dissuades it from trying to interfere with the process.
We have gotten a quite a few bug reports due to this crapware being bundled by motherboard vendors and even some oems like Alienware and Lenovo the past year or so. It seems discontinued as the company was acquired by SteelSeries, but they also have a new product that boasts the data mining software that they promise enhances your audio, lmao
It’s still working fine over here. I have not tested the test builds. Still on 7.0.7. All I did was kill all processes of nahimic and uninstall some audio softwares. But still it’s NahimiServices.exe poping up in the processmanager but as for now. It all works. Will try harder to get rid of all nahimic BS.
Thx very much for the support of this. You saved my day!
