Do you know of a Kicad project on high voltage sparks?
I want to make a board for an electric pastor. I have seen that it is necessary around 10 Kv. I have seen that it is possible to achieve with an inverter flyback like this
But I have seen this other one that seems better to me, there it says 40Kv but I don’t think so since the maximum distance is 1.2cm so it must be around 10Kv
My idea for the KiCad project here is to make a pcb where it is easy to connect a 10W/12V solar panel, a battery and a high voltage module like that and anyone who can build and install their own solar shepherd.
What you need is a portable battery powered Electric Fence Energiser.
They have been around since Adam was a boy
$30 US will get you the energiser. $70 US will get you the Energiser, 12V gel-cell battery, voltage regulator, and Solar Panel, all from Aliexpress with free post… pretty hard to beat.
Bulls need about 10KV, cows a bit less, horses about 2KV and they don’t really work for sheep. Horses also need a much shorter discharge time than cows or the shock will kill them.
These are cots (Common Off The Shelf) mass produced items.
It’s probably not worth the time and effort to try to make one yourself, unless you get the parts for free, don’t put a price tag on your own hours or just think it’s fun to make such things.
As far as I know, It’s not really about the voltage, but about the energy. Years ago Davey Jones (EEVblog) did a teardown of a high quality unit. From that you can get an idea of what in those things.
I also don’t know how sensitive horses are in this regard. How big of a margin do you have between “not effective” and “Killing your horses”. Such circuits have to work reliably for many years in harsh outside conditions (condensation, moisture).
Electrical energy required:
The maximum energy allowed by the regulations for electric shepherds is July 5 with a maximum voltage of 10,000 volts, and the minimum that must be marked on a fence is 3,000 volts, because from there down it would not be safe to contain the animals.
In many countries a “electric shepherd” must be off part of the time. My fence is on 1 second off 2 seconds. This allows time for a person to get off the fence. A animal just touches the fence. A person will grab the wire with his hands. The electricity will cause the hands to hold on and not release. There must be time with no electricity for a person to open up the hands.
I know this the hard way. It is very hard to get off the fence.
With a human it doesn’t work, if the human has shoes.
Only the positive is used in the fencing. The negative is the earth. You can make another configuration where one cable is negative and the upper one positive, but it is not normal, it is used when the other does not work. For example due to a poorly conductive floor.
The horses play it once, psychologically it is recorded on them and it does not play again. Today I tried to get an American quarter-mile foal to get close to the conductor wire but it wouldn’t touch it.
