Simulation Problems MAC
Hello everyone!
I am totally new to KiCad and Eeschema. I am running KiCad 5.1.2-1 on MAC osx 10.14
I seem to be unable to run any simulation that includes downloaded spice models. I am trying to understand how to make this work by simulating a simple non-inverting opamp based amplifier using the Texas Instruments spice model for a TL071 (TL071.301).
Once i upload the model into the symbol and run the simulation i get an error saying:
“Circuit: KiCad schematic
Too many parameters for subcircuit type “tl071” (instance: xxu1)
Error: there aren’t any circuits loaded.”
I know that the pin number on the spice model are different from those in the KiCad symbol; although when i input an alternate node sequence both KiCad and Eeschema crash as soon as i try to run a simulation.
Any help is appreciated!
Thank you very much in advance.
The model requires 5 pins.
The TL071 symbol from the Amplifier_Operational library has 7 pins, but the offset correction pins 1 and 5 are not served by the model.
So use a 5 pin alternate node sequence
3 2 7 4 6
For checking out other simulation options, you may have a look at http://ngspice.sourceforge.net/ngspice-eeschema.html
Hello holger, thanks for the reply!
That is exactly what i did, however if i input a 5 pin alternate sequence KiCad and Eeschema crash as soon as i hit the play button for the simulation.
Even if it refuses to simulate, it nevertheless should not crash.
Could you please post your eeschema input file (*.sch) here for a check?
Sorry for the late reply, please find attached toe schematic file, i have also attached the simulation model that i am using. Unfortunately it won’t let me upload the files directly as a new user…i have thus attached a link, sorry for the inconvenience.
https://we.tl/t-WIBxW8ppR7
Thanks a lot for your help!
Download the *sch file.
Edit Spice model: Set correct path and filename of model file TL071.301.
Start simulation: everything is o.k., output is there.
5.1.2-2 on Windows 7, using ngspice-30.
So…funny thing is, i have created the same project again from scratches just to see if i had done something wrong along the way and used the same TL071 model. Now it doesn’t crash anymore…but i get an error message:
Original line no.: 7, new internal line no.: 51:
Mismatch: 0 formal but 1 actual params.
Copies=55 Evals=54 Placeholders=0 Symbols=3 Errors=1
Numparam expansion errors: Problem with input file.
Error: ngspice.dll cannot recover and awaits to be detached
Note: can’t find init file.
** ngspice-26 shared library
** Creation Date: Wed Apr 24 18:39:08 PDT 2019
I am even more confused now haha also, shouldn’t Kicad 5.1.2 have ngspice30 integrated (i have ngspice installed on my MAC anyway)? why the error message mentions ngspice-26?
macOS is still 5.1.2-1 with ngspice-26.
You may try https://kicad-downloads.s3.cern.ch/osx/testing/5.1/kicad-5.1-unified-20190625-045229-d829e0044-10_14.dmg, that is the coming bug fix release. It may or may not have ngspice-30 (I don’t know and cannot test). See the discussion here: https://lists.launchpad.net/kicad-developers/msg40948.html
Latest news about KiCad for macOS and ngpice 30 on https://lists.launchpad.net/kicad-developers/msg41302.html
IT ALL WORKS NOW!!!
Installing the patch found in the link provided by NICKOE solved the issue!
Thanks a lot for all your help!
