Simulation Aborted
Application: x86_64 on x86_64
Version: 8.0.0, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.2.0
FontConfig 2.14.2
libcurl/8.4.0 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.11 nghttp2/1.45.1
Platform: macOS Monterey Version 12.7.3 (Build 21H1015), 64 bit, Little endian, wxMac
Date: Feb 23 2024 15:23:55
Boost: 1.82.0
OCC: 7.7.2
Curl: 7.87.0
ngspice: 42
Compiler: Clang 14.0.3 with C++ ABI 1002
Apart from crashing occasionally, I had a simulation working for a short time. But now it doesn’t and outputs this:
Note: Compatibility modes selected: ps lt a
Circuit: KiCad schematic
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Using transient initial conditions
Warning: singular matrix: check nodes xu1.xu1b.x1.xu3.7 and xu1.xu1b.x1.xu4.8
doAnalyses: TRAN: Timestep too small; time = 1e-16, timestep = 1.25e-17: trouble with xu1:xu1a.x1.xd4:idiode-instance d.xu1.d.xu1a.x1.xd4.d1
run simulation(s) aborted
Sometimes it says it can’t find a .DLL file, but I’m using macOS.
Anyway, I’m stuck and need some guidance. Any offers?
No offer without complete project (circuit plus all external models used).
Thank you Holger. Complete project here:
Sim_acdc.zip (280.7 KB)
Thanks for the project.
I got it up and running by adding the line .options rshunt=1G into a text box of the Eeschema canvas. There is some model incompatibility which might need further investigation.
To obtain a stable output, the simulation time has to be 1 s or so. Thus I have raised TSTEP to 20u to spped it up at least a little.
Thank you Holgar. For me to begin understanding the many command directives, I would need some kind of a a graph showing what “Time step”, etc. actually does. Your videos are very good for getting started, so I hope to watch future editions focused on commands.
Meanwhile, please can you show me how to simulate a repeating tone burst. Something like a repeating sequence of a 1kHz sine wave for 300ms followed by 500ms of silence. This is the kind of thing my hardware function generator does with ease.
Any suggestion how to achieve this?
Here’s another simulation I can’t get working.
Sim_k-filter.zip (56.1 KB)
