I also found a difficulty of using directive to run simulation on serval difference pspice tool (ngpsipce, and TLSpice etc.) What I found were that each tool have difference control, or not every spice simulation accept the control block. So when I use directive, I often have to include, and exclude back and for depend on the tools. Are there way to made this easier?
- The include, and exclude from simulation text graphically look the same. If they look difference that you also help I think.
- If directive some how generate two difference netlist files base of the “directive text”. So I could run simulation on ngspice with netlist 1, and LTSpice with netlist2. May be like - “.netlistprefix ngspice”, and other text “.netlistprefix tlspice”.
