Screening Can - Any good methods for setting up a symbol
Hi All,
has anybody got any good methods for creating a screening can symbol e.g. dotted lines to encompass the area of the circuit to be enclosed ?
Needless to say, I can create a ‘dummy’ symbol with the pins for the ground connections and then add dotted lines manually, but I was wondering if anyone had found a better way of doing it.
Many thanks in advance for you thoughts and ideas.
Stewart
I did a little search . . .
The question was about symbol and that what I have written in 2018 was about footprints.
Just off the cuff, haven’t tested it fully, but how about drawing a wire box or polygon around the area in question, then change its line style to dashed or dotted as you wish. Then attach it to the GND net with a symbol that can be associated with a suitable footprint, say a 1 pin connector. Here’s one I whipped up.
wire-box
I needed to make a shield - after making it, I discovered that I no longer needed one but had already made the Symbol and Footprint.
They’re only representations of what I intended to do but good enough to convey the idea… No Lid/Cover on the shield but, that’s only 5-minutes of work…
This shield was only a test for a Generalized Footprint… on PCB with some thrown-together parts… Not a real PCB
You can get Shield geometry from the Shields at Mouser/etc…
Hi All,
many thanks for the collective thoughts and ideas.
Really helpful !
Thanks again for taking the time and trouble: It’s very much appreciated !
Kind Regards,
Stewart
