I have designed two separate PCB for my client. After the first prototype, I found some issue to connect two PCB together. PCB constraints are very low to put connectors on the board. I want to design Rigid Flex PCB. I have done many boards in KiCAD but Rigid flex PCB is very new to me. I don’t to how to set constraints for the rigid flex PCB design. My previous design constraints are below. First Board
Layer: 4 Layers
Dimensions: 13mm Dia Circle Second Board
Layers: 2 Layers
If anyone has done Rigid Flex PCB in KiCAD please help me on this.
Sorry, It’s Rigid Flex PCB. And my design has two 13mm Dia Rigid PCBs. Right Now I am using 1.27 mm SMD pin for connecting two boards. I want to eliminate the 1.27mm pin by replacing Flex PCB for connecting two Rigid PCB’s.
