Remove '/' prefix from netnames in spice netlist
I cant find the setting to remove or change the ‘/’ prefix of netnames in the spice netlist. It is confused with division in the mathematical processing and makes a lot of scripting and plotting impossible without tedious, manual rewriting of the netnames.
Is there a preference setting to remove the prefix or change it to something more compatible with spice syntax?
Sincerely,
Sigurd
Use global labels instead of local labels. The slash comes from the sheet path (your local labels are presumably in the root or / sheet)
