How to reassign a pcb track net ?
I had a situation where a simple change in the schematic could be easily routed by utilising an existing pcb track that was now redundant.
What I found is the net name has to be manually removed from the track segment by segment , before I could easily reroute the track to a new net.
Is there a way to highlight a complete trace and re-assign a net designation
eelik
2
Which version? xxxxxxxxxxxxxx
V6.99 nightly as of about 4 days ago
Click on a segment to select it.
Do a u
to select all connected segments.
Do an e
to edit the properties.
There’s a net dropdown in the dialog.
thanks too, i was all facing this problem.
system
Closed
7
