Now there is the last step: create an image from these files, I googled a little bit around and found this but honestly i wan’t very lucky and it didn’t worked (maybe problem between windows and cairo), anyone would like to give any hints about the code? or would like to help? now it is working
Are you planning to put this out on github? I was writing a similar script and came across this. I’m glad to see you put the hooks for the plugin. I was going back and forth if I wanted to make this CLI. I think this makes more sense. As, I scrolled down the code you have posted, I think there is an indention that is missing for the generate_drill_file def. Based on the work I’ve done, this looks like it will likely do what I was working on. I’ll post if I run across any bugs or issues.
