I have written some code to generate gerbers, but after a closer look, they are different (generated with the same settings) and I don’t know why.
Here is the python code:
def plot_gerbers(board, output_path):
plot_controller = pcbnew.PLOT_CONTROLLER(board)
plot_options = plot_controller.GetPlotOptions()
plot_options.SetOutputDirectory(output_path)
# Set General Options:
plot_options.SetPlotFrameRef(PLOT_FRAME_REF)
plot_options.SetPlotValue(PLOT_VALUES)
plot_options.SetPlotReference(PLOT_REFERENCES)
plot_options.SetPlotInvisibleText(PLOT_INVISIBLE_TEXT)
plot_options.SetPlotViaOnMaskLayer(PLOT_VIA_ON_MASK_LAYER)
plot_options.SetExcludeEdgeLayer(PLOT_EXCLUDE_EDGE_LAYER);
plot_options.SetPlotPadsOnSilkLayer(PLOT_PADS_ON_SILK_LAYER);
plot_options.SetUseAuxOrigin(PLOT_USE_AUX_ORIGIN)
plot_options.SetMirror(PLOT_MIRROR)
plot_options.SetNegative(PLOT_NEGATIVE)
plot_options.SetDrillMarksType(PLOT_DRILL_MARKS_TYPE)
plot_options.SetScale(PLOT_SCALE)
plot_options.SetAutoScale(PLOT_AUTO_SCALE)
plot_options.SetPlotMode(PLOT_MODE)
plot_options.SetLineWidth(pcbnew.FromMM(PLOT_LINE_WIDTH))
# Set Gerber Options
plot_options.SetUseGerberAttributes(GERBER_USE_GERBER_ATTRIBUTES)
plot_options.SetUseGerberProtelExtensions(GERBER_USE_GERBER_PROTEL_EXTENSIONS)
plot_options.SetCreateGerberJobFile(GERBER_CREATE_GERBER_JOB_FILE)
plot_options.SetSubtractMaskFromSilk(GERBER_SUBTRACT_MASK_FROM_SILK)
plot_options.SetIncludeGerberNetlistInfo(GERBER_INCLUDE_GERBER_NETLIST_INFO)
plot_plan = [
( "F.Cu", pcbnew.F_Cu, "Front Copper" ),
( "B.Cu", pcbnew.B_Cu, "Back Copper" ),
( "F.Paste", pcbnew.F_Paste, "Front Paste" ),
( "B.Paste", pcbnew.B_Paste, "Back Paste" ),
( "F.SilkS", pcbnew.F_SilkS, "Front SilkScreen" ),
( "B.SilkS", pcbnew.B_SilkS, "Back SilkScreen" ),
( "F.Mask", pcbnew.F_Mask, "Front Mask" ),
( "B.Mask", pcbnew.B_Mask, "Back Mask" ),
( "Edge.Cuts", pcbnew.Edge_Cuts, "Edges" ),
( "Eco1.User", pcbnew.Eco1_User, "Eco1 User" ),
( "Eco2.User", pcbnew.Eco2_User, "Eco1 User" ),
for layer_info in plot_plan:
plot_controller.SetLayer(layer_info[1])
plot_controller.OpenPlotfile(layer_info[0], pcbnew.PLOT_FORMAT_GERBER, layer_info[2])
plot_controller.PlotLayer()
plot_controller.ClosePlot()
The Simple gerber generated by KiCad GUI
G04 #@! TF.GenerationSoftware,KiCad,Pcbnew,(5.0.1)-3*
G04 #@! TF.CreationDate,2018-12-06T22:00:52+01:00*
G04 #@! TF.ProjectId,Sample,53616D706C652E6B696361645F706362,rev?*
G04 #@! TF.SameCoordinates,Original*
G04 #@! TF.FileFunction,Paste,Bot*
G04 #@! TF.FilePolarity,Positive*
%FSLAX46Y46*%
G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)*
G04 Created by KiCad (PCBNEW (5.0.1)-3) date 06/12/2018 22:00:52*
%MOMM*%
%LPD*%
G01*
G04 APERTURE LIST*
%ADD10R,0.750000X0.800000*%
G04 APERTURE END LIST*
D10*
G04 #@! TO.C,C3*
X52700000Y-39600000D03*
X52700000Y-38100000D03*
G04 #@! TD*
M02*
And the one generated by the python
%TF.GenerationSoftware,KiCad,Pcbnew,(5.0.1)-3*%
%TF.CreationDate,2018-12-06T22:12:26+01:00*%
%TF.ProjectId,Sample,53616D706C652E6B696361645F706362,rev?%
%TF.SameCoordinates,Original%
%TF.FileFunction,Paste,Bot*%
%TF.FilePolarity,Positive*%
%FSLAX46Y46*%
G04 Created by KiCad (PCBNEW (5.0.1)-3) date 12/06/18 22:12:26*
%MOMM*%
%LPD*%
G01*
G04 APERTURE LIST*
D10*
%TO.C,C3*%
%TD*%
M02*
They are almost the same but differences lie in the comments line:
in the KiCad GUI generated:
G04 #@! TF.FilePolarity,Positive* <- this is a comment preceded by G04
%FSLAX46Y46*% <- this is a parameter
in the python generated:
%TF.FilePolarity,Positive*% <- is this should be marked as comment? preceded by G04? or not?
Maybe I have a incorrect settings in python script to generate gerbers properly?
