You first need to have Python installed. Once you have that, then you use the command easy_install kifield or pip install kifield and the program will be installed where Python can find it. You don’t have to be concerned with moving files or where they are stored.
Then you can use kifield at the command line. Just type kifield -h and you’ll get the help information. I assume you’ve found the documentation.
The OP also needs to be instructed for which version of Python to have installed… 2.x (currently 2.7.13) or 3.x (currently 3.6.1). I hope 3.x, but personally I don’t know.
When everything is set up right, python is very similar on any OS, which is a nice feature. When things go wrong, or you need to look under the hood, there are of course big differences in implementation between OSes.
If you installed Python and selected the option to “add to system path” then you can start a Command Prompt and run Python, and the associated tools like easy_install and pip.
Otherwise, you need to add the python paths : c:\python27;c:\python27\scripts
C:> path %path%;c:\python27;c:\python27\scripts
Assuming python was installed in c:\python27.
With python on the path, you can run python, easy_install and any other installed packages from any folder like any DOS command.
easy_install (and pip) will look on https://pypi.python.org/pypi to find packages, so you don’t need to download a zip if the package is registered on PyPi. Python packages are installed into C:\Python27\Lib\site-packages, and a command launcher for the package is created in C:\Python27\Scripts, so you can run the package like a command.
If you install python 3.x on windows it will even add some dll to your windows system32 folder which then allows co-existence between 2.7.x and 3.x without the inserts into the PATH variable.
You can remove them.
On the command line for the live interpreter to appear you just type
py -2
for python 2.7.x and
py -3
for python 3.x
If you write scripts add this in the first line to tell the launcher which interpreter to use:
Er..installing Python 3 to avoid changing the path seems like a sledgehammer to crack a nut?
Python 2/3 compatibility introduces a whole new set of problems. KiCad has python2.7 built in, so if you need to run a script in KiCad it needs to be Python2.7.
If you run a python script in KiCAD, the KiCAD environment should take care of picking the correct interpreter that comes with KiCAD and not have any problems with what python versions you have installed outside of KiCAD’s scope.
If KiCAD can’t do that, it’s about damn time…
Suggesting to install 3 in parallel to 2 is about removing the python PATH from the windows PATH variable and not have any python scripts run into version problems because of exactly that reason.
The python launcher under windows takes care of it.
That’s the clean and proper way IMHO.
And to come back to the OP… he wanted to run KiField, which is a 3rd party python script run outside of KiCAD afaik, running on the python interpreter that your system has installed and doesn’t even care for 2 or 3.
This is all very much PATH Dependant, as I figured from the start.
Yeah, I think we are NOT on the same page here.
Windoze 7 does NOT work like indicated as a newcomer trying to learn this stuff.
In order to make kifield work, I had to move a copy of my kicad.sch file to the C:> root location.
The instructions don’t state anywhere that paths matter, and they apparently DO. Nor, are there instructions about the SYNTAX of the path requirements.
To expect the average user of KiCad to have to learn and navigate all of this is ridiculous.
That’s the state of affairs.. at least KiField and KiCAD are free and you can change the code if you don’t like something.
If this stuff was easy most of us would be doing something else. (*)
As for why you have problems with your path.
Install python 3 as well, it will place a dll in your system32 folder which will make this all way less painful in regards to python.
*) like wonder why Microsoft decided to cut off service updates on Intel 7th generation processors. And not even my fault, I had to get a bew CPU+RAM+mobo, becuase my old one died and I couldn’t get a new mini-ITX mobo for LGA1150 socket here in Oz.. (4th gen).
No one tells you upfront that you will loose serviceability via Windows updates of your OS (inclusive safety patches) if you run windows 7 on a 7th gen cpu.. luckily some dude wrote some code, put it on github and I got my safety patches working again. Argghhh..
